(#46)
Default 12-21-2016, 12:05 PM
Originally Posted by Nicky92
I don't see me doing that, but if it was to happen, any engine damage could occur? or would it just give me a code, limp mode, etc?
Fuel pressure would drop and either kick you to map 4 and/or the engine will stumble.
Dave is correct, we anticipate Option 1 to be $149.95. It's difficult with the manufacturer because they do an initial run quote after they are already built and then do the final production quote after that. Based on our discussions with them $149.95 should be pretty accurate.
Originally Posted by Turbeau
Will the top hat spring will push the Walbro filter all the way to the bottom of the tank?
Yes, the spring keeps tension on the pump assembly forcing the filter to stay at the bottom of the tank just like the stock bucket.
