08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Car: 08 335Ci
Default 12-04-2017, 09:15 PM
I prefer Bilstein, but getting hold of a set up is damn near impossible until sometime next year. If you can find a set, you're a blessed man.
Because the Bilstein's were unavailable the guys at Turner suggested the KW V2's. The front struts are polished Stainless Steel, rear shocks are painted (powder coat?) black and the springs bright yellow. And they do work. Better then the stock Msport suspension. Probably the point I like the most, I didn't need spring compressors to assemble the front struts.
The only problem I had with the KW's .... I got 2 left front struts even though one was labeled R. Sent pictures to TMS and KW shipped the correct strut that afternoon.
No matter how fast I go there's always someone slower in front of me.
You can lead a horse to water but you can't make him Jet Ski.
'10 E92 335 M Sport, JB-4 G5 ISO, 3" CPE Charge pipe, WMI w/dual CM 5 nozzles, 3.5 Tmap, ARM Relocated Inlets (don't do it), VSRF Outlet, BEF, Front Strut Brace, SS brake lines, Drilled and Slotted Rotors, Anti-lag, OCC. Escort Max 360
Totaled by a careless driver:
'08 E92 335, M sport option
