(#4596)
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 09-30-2019, 07:41 AM
Does it make normal boost from a roll? What you say you brake boosted, what RPM?
Yep, normal boosting when rolling prior to getting to my test location. Was driving on Map 3 due to the heat and had no issues.
I first only brake boosted to about 1500 and the car flopped hard. Didn't even finish the run. Backed it up then launched from 2000 which usually causes me to spin. Car flopped again. The heat isn't easing up this week (97 on Thursday for some ungodly reason) so I can't test it in a cooler scenario to chalk it up to the heat.
12.64 @114mph
0-60 4.46
