(#2435)
Default 04-24-2016, 10:20 AM
On the 4bar 2ABD starup fault I think the issue is with the conversion on the JB4 end at certain elevations. If anyone can easily recreate the issue and has time to test a fix email a short CSV file from idle, and I'll send a JB4 firmware to test. Thanks.
For flash only guys, I suspect the 2ABD flash only issue is with the lower end of your map conversion value. You might need a TMAP MIN voltage table added also.
