Low vacuum from boost controllers -
09-12-2021, 09:44 PM
Recently bought a “project” . 09 535i 6spd. 130k miles . I’ll skip all the original problems and fast forward ( after many hours and parts) to where it sits now.
New OEM turbos, all intakes, hoses, oil pan gasket, w pump, radiator, walnut blast and more.
Problem: 4 psi boost. I have measured this a couple of different ways and I’m sure it’s correct. Also, I owned a n54 in the past and have an idea how it should pull.
Diagnosis done: over 25” of vacuum TO boost solenoids at idle. I tee’d into the vacuum lines FROM the solenoids to the turbos and read the vacuum when driving. At first, car pulls hard for about 1/2 second ( and vacuum to turbos/ waste gates is over 20”). Then vacuum drops to maybe 5” and so does the power. It holds about 4psi boost under sustained full throttle.
My thought: computer is killing the duty cycle on the BC solenoids and also the vacuum. I can’t find info with enough detail that describes the circuit and parameters of the BC solenoids and what affects their duty cycle.
Only code is 2AAF. I have searched for a couple days and found no similar problem but maybe ( obviously) missing something here. Thanks in advance for help “
