Default 10-21-2019, 10:49 AM
Originally Posted by deerok78
Hello Terry,
I just ordered the JB4 and its on the way, on MAP 1 will i need to get colder spark plugs like you do with the 3.3?
Also I have intake and turbo inlet adapter coming ..will that all still fall under MAP 1 ? and im sure the JB4 will adjust to the intake added
Thanks for the help, look forward to installing this.
Should be okay for map 1 if you have lower miles. What fuel will you be using? Post logs once installed!
