We offer limit N63 tuning support because it's such a headache. Read the codes, and then come up with a plan to correct them. Common codes are the MAF sensors needing to be replaced. If misfire then there are a host of possible causes for that separately.
I have only 2 codes:
180008 Catalytic converter: Efficiency below limit value (not validated)
102302 Air mass flow sensor, operating range: Cycle duration too low, air volume too high
The 180008 is obvious, I have no catalytic converters 🤷🏻*♂️
The air mass flow one I have no idea (this caused a DTM while I was at ~80% throttle)... The small log I have showed really high trims (above 40-45). That was on map 2! I have some 3.5bar sensors but need to order some connection kits because I have the deeaded type connector and I was told that it doesn’t work properly without it 🤷🏻*♂️
On map 1, the app shows the o/u bosst always at -4 and the 2 boost dials don’t show anything even at full throttle. I have to run map 6 at 3.5psi to have a relatively stable tune. Even at 3.6psi, I get DTMs with map 6...
With all the police around on the roads, it’s practically impossible to do a wot 3rd gear pull, so don’t ask!
I really have the impression that I paid 900$ for something that is only partially working.
Does anyone have any idea to help me?
