Had a customer connect the JB4 connections in the wrong spot limiting boost. Be sure rainbow patch is on the MAP sensor as shown!
Hello there
I just wonder how can I install the connector of map sensor. there is conflict between the installation guide and this post of the forum which shows the wrong and correct installation method of map sensor on manifold ? could you illustrate which one is correct?
many thanks.
