CakeFladudle CakeFladudle is offline
Car: 2020 accord 2.0t
Default 07-08-2020, 10:59 PM
First I've heard of a turbo failure on the platform but running higher boost levels does increase risk, especially if there was a weak point from the factory.
Sure you didn't blow off a chargepipe? If a turbo fails you'll have tons of smoke out the exhaust usually.
Came to the conclusion from driving it that the turbo is working and the lights turns off that time. But it happened again on map 2 and im getting the code 0234. Do I need to change something in the setting to fix this problem? Or do you think its a mechanical issue with the wastegate?
