AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 05-01-2019, 06:42 AM
basically you guys are spraying so much meth (fuel) that the car needs to remove some to hit the AFR target but it's already holding back the maximum amount it can with trims on the current tune on the DME.
You will need to adjust the fuel scalars so that its in a better range where it can be closer to 25. Adjust a back end flash. Of course you could raise the boost which requires more fuel.
