Thread: Log Review
Tripp3 Tripp3 is offline
Car: 2010 e90 335i m sport
Default 09-17-2018, 03:27 AM
Originally Posted by Dave @ Fuel-it!
Hey,
Couple things- boost looks ok, could use some fine tuning.
LPFP looks about maxed- dips into the 50s
AFR looks a bit lean for my test at 14.x:1 after hitting target- Id load the BEF asap
Appreciate it!
I will go ahead and get the BEF sometime this week.
After getting the BEF would it be alright to just run MAP 2 with the current setup and 93octane? Or should I log on MAP 1 and if it looks ok then change to MAP 2?
(currently using MAP 5)
running DCI, FMIC and 93 ocante. Not that it matters but CP and BOV also..
Last question is how does the timing look? Seems have quite a few variances.
