rickz96 rickz96 is offline
Car: e60 535Xi
Default 05-21-2019, 02:10 PM
Dave,
Attached are the map 2 logs. They look ok. data timestamps of interest are around 235 & 349. My only question is why does the trim value consistently take a dip from 2000RPM to 5000RPM, trying to pull fuel out? Otherwise looks relatively normal - no? Take note my FOL value is still down at 40. Should I change that manually back to normal range, or let it stabilize on its own?
Thanks for all your help with this!
