JBoe JBoe is offline
Car: M240i
Default 03-05-2019, 09:20 PM
looks better, but you should provide a log that's like your first. A nice long pull from about 2500rpm in 3rd or 4th gear. Your first log is the correct method. I've heard that ********* can cause the overboosting, but this is the first I've seen it so clearly. You may have to get the EWG wires to correct this.
Payam will chime in soon. Timing and trims look good from what I see. Just need to get boost more under control.
