Default 10-15-2018, 07:48 AM
Originally Posted by RMM
might try rise your target to 17 form 3500 - 4500 RPM, that will help with the throttle closure shown in the dyno run
or alternatively reduce the DB in that region a little (by 5-10) to prevent it form boosting over target, either way should prevent the throttle closure to occur
The throttle movement is caused by the DME dropping it's target there. You can see minimal impact on the manifold boost, though. So probably not causing an issue.
