Default 01-19-2022, 12:38 PM
Originally Posted by gnutzie
I have been running menu 4 at 4 with the wastegate actuator connected to the stock harness, because this is the only way I can avoid the boost creep. I want to go back to being fully enabled to control boost but it’s not drivable like that currently
I reconnected it to the JB4 because you asked me for a log with it connected.
If you want me to log with menu 4 in a different setting then let me know.
Yes...I wanted to see the difference. If running menu 4 set to option 4, JB4 has no boost control and you can see that there is no WGDC coming from the JB4.
Do you have a flash loaded? If so, set menu 4 to option 2 and lets see a log on map 4 with the boost solenoid wires connected. If not, set menu 4 to option 3 and do the same.
