(#369)
justme justme is offline
Car: 550
Default 06-12-2018, 01:58 PM
The enclosure appears to be 'mostly' sealed. There is a wire tap that is on the outside which could present an issue. I'm thinking that a little flexible silicon on/around things should help to ensure that it's sealed. Would just have to peel it off if anything needed to be serviced.
If one adds the BCM, what needs to be done? eg: might need to wait until after the BCM is installed to make sure that I'm not ripping apart again.
