Default 10-12-2021, 08:27 AM
Ideally you want a sustained full throttle pull with shifts, like 40-100mph, on a safe private track, for example.
Runs seem pretty normal for 91 octane gas which is very low octane. Expect plenty of timing corrections with it stock and tuned on 91.
psi2 is lower than psi due to throttle position, which seems pretty low. Do the next set of logs in comfort mode for comparison.
