(#4394)
DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default 11-14-2017, 01:55 AM
Originally Posted by Dmac @ BMS/DMD
Made a few new changes to the iOS beta which should improve functionality. Please test and let me know if you have any issues. The Q50 stuff is also in this build. Should be up in the next hour or 2.
Android:
Fixed the bug with the missing trims item in the dropdown. Beta with that fix and Q50 additions will be live later tonight.
If all goes well over the next 24-48 hours I'll release both builds to the public channel.
When is it going public for Android?
