Thread: Map3 log
JBoe JBoe is offline
Car: M240i
Default 05-07-2019, 10:41 AM
Your trims are maxed out. While things look good in the log, it's on the edge and could go badly depending on conditions. I'd get the FF wires hooked up and set FOL to 20, then relog. You should see trims lower. A short spike/max at onset of boost often happens, but it should come back into control quickly. Keep it under 40 and above 30 on trims and the car should be happy and safe. That's my .02
Timing looks consistent, but has a few dips in it. That's probably related to trims. Get FF installed, adjust FOL and we'll see where you end up.
