Six Pot's Avatar
Six Pot Six Pot is offline
Default 04-22-2019, 07:44 AM
If you want to go even more OEMish you can also use a 1M heater line that connects from the firewall to the hose that typically clips into the upper radiator hose. No trimming and has the Y that was intended for the secondary water cooler. Runs just fine :-)
(TOP is OEM, Bottom is the 1M. push adapter removed from Y to accommodate VIE can)
2011 BMW VO 1M
ViE 3884 GTW 67mm 1.0AR Hot Side T51r Mod | PR Coil Packs
JB4 ISO | MHD | PR Stage 4 Elite | DOC Intake Manifold + TiAL + Pi
Seibon Dome Hood | Spec Twin Disk | PSP 900 IC | Slek Front Lip / Diffuser
Apex EC7 Wheels | KW HAS | N55 Mid + Y Pipe | P3 | ADe Catch Can
