Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 02-19-2021, 06:51 PM
Originally Posted by cire
I already bought the valve cover i just assume replace at this point when itís off. The shocks I was going to go with the bilstein b6. Iíll have to order top and bottom mounts as well as the other parts, at least they will be on hand if I have to change.
I believe the B6 yellow comes with its own dust cover ( blue ) for the rear, in case it's with its own blue dust cover then you don't need the OEM dust cover
