(#4031)
Hokie135 Hokie135 is offline
Car: 2009 135i
Default 09-22-2021, 06:37 AM
I'm dialing in my Pure Hi-Flows now and testing the different maps so I had the same questions.
In short, if you are only using 93 Octane or up to E30 mixture, you'll want to start with PUMP. You are correct there are no specific PUMP Hybrid maps. Which is confusing but it does make sense once you understand Bit6 and the other settings.
The next map you may want to experiment with once you have PUMP dialed in is RACE. This will give you more aggressive timing or allow you to work with some lower E85 mixtures. If you will never try E85 mixtures, I don't think you'll need the E85 maps.
I am personally experimenting with RACE now.
I hope this helps!
