Looters Looters is offline
Car: C43
Default 11-07-2020, 06:34 PM
Mind taking a look at these logs? Lowered e85 to roughly 2.5-3 gallons on full tank of 93...I ordered the bcm and installed and first pull after install was easily the quickest the car has ever felt. Few minutes later did a quick 40 to 70 pull and felt super sluggish. Here's both logs. I also replaced both map sensors to rule that out. Any other ideas what to look for or causes?
They are o2 sensor/fuel trim sorts of faults. Probably due to the E85 mix. As a test could lower the E85 mix.
At WOT boost looks lower, but temperature is also colder, so you'll have less of a target. If there isn't a boost leak then adding in a BCM would really wake this car up I think.
