E92 420 E92 420 is offline
Default 09-18-2020, 11:38 PM
Originally Posted by KnighTT
So, If I picked up a set of JE pistons with the 9.5:1 compression, you can correct CR back to 10.2:1 when you have your head decked, right?
I just don't want to pay for the CP pistons at $1100+ just because they are set to 10.2:1.
I mean I'm going to get the head worked on anyways.
Pros, cons, remedies?
You could probably do it by removing material from the head and or block yes. However JE make 10.2-1 pistons as well you know.
UK V8Bait Tuned
Built Motor
TD Turbo 335i
