(#717)
Default 07-13-2018, 01:16 PM
Note: Firmware and use notes to enable this is now in the specificJB4 threads!
So it turns out JB4 2STEP + JB4 anti-lag = awesome!
Do do this you need:
1) A general understanding of how the JB4 and firmware updates work. If you don't know how to update firmware you probably don't have the requirements to run this.
2) JB4 anti-lag working including back end flash map loaded all per the first post in this thread.
3) The 2STEP relay installed and generally working.
4) The firmware below which integrates the two together while under two-step.
To enable antilag+2STEP integration with v14+ firmware set bit3 on the WMI page (mislabeled DTML WMI input) on.
I'd start at 3000-4000rpm as a set point on menu8 and evaluate from there. The anti-lag integration will probably require some additional adjustment to our 2STEP targeting logic so I'd be curious to see how it targets various set points for various turbos and flywheels.
