https://i.postimg.cc/MpxdP23T/BCMplug.jpg |
that's not the connection I had trouble with, it's the BCM to the wastegate control connection. I just went and played with the retaining clip on that female connector and it finally stuck on.
I revisited the connector and reinserted that piece today. I got it to lock in like above and the connector plugs in as it should. I drove for a week with it removed and it was fine. Doesn't seem to do much but maybe guide the mating connector better.
I have a 2018 audi a4 quattro. I purchased a jb4 3 months ago and lately only boost gauge would work and car felt sluggish. If I turned it off and let it sit for 10 min and turn back on all my gauges would work and it would come alive so I updated my firmware to audi vw_8 4. AND IT DIDN'T WORK . I need someone to point me in right direction plz.
Just email George@burgertuning.com!
Hello, i just installed the jb4 for my s5, i plugged the obd and There is no difference between map 0,1,2 and 3... :(
Im runing on gas 92 octanes Its like the car was stock, i tested with the racelogic vbox and there is no difference, what could it be? |
here are the 4 logs!
4 Attachment(s)
map 0 to map 3
Im using 92 octanes, what can i do? What do you mean with timing correction? Sorry im new with this!
Thanks Terry! |
I think for the short term stay on map1. And George can work with you to see if there is a way to boost performance on the octane.
I'll have to get a picture when I get into the office today unless you can get one. It's a small white tab that needs to slide over when the terminals are pushed to the top. |
BCM
i had trouble with both connectors but they are ok now. the pink clip was in the way and i managed to adjust that. also on the other connector, part of it wasn't seated correctly (a grey circular clip at the base of the inside). i pushed that across with a screw driver and voila.
now i need to go have a run and take some logs so that i can get a nice custom map 6 worked out. any suggestions for that as a baseline? the settings on page 1 have it zeroed out but there were boost settings in there originally that i removed so it matched the recommended settings. |
1 Attachment(s)
Just fitted my JB4 to RS4
Just had run out after fitting the unit to do some logs and the car feels great. Only used map 1-3 but midrange already pulls great. :). Sent logs over
1 Attachment(s)
I noticed today on some of my logs the graphs seem to be off ? I am shifting at 6k and tje logs only show 5k and boost #’s seem to not be what im seeing on the guages. Is it just me? Lol
So it seems if i just sit at idol the data logging is counting the paramaters for time like idol guage is 823 -8-30 and the jb4 keeps logging increase rpm with relation to time same with boost! Odd?! |
You're probably looking at the wrong log.
