Terry - being that I'm getting IAT's of 130-170 on pulls, would I see much of a difference if I installed a larger intercooler? Would I only get a benefit after multiple pulls, or would it help with baseline? |
Yes it's one of those problems that comes up every couple of days or weeks. So we have to make a change, and drive a lot, to see if it was resolved.
Larger IC would lower IATs for sure. We're working on one. |
Both of those features would be huge for this Texas heat
Would not mind testing in Canada with our 94 gas even with the random error. Can't wait to test...
Terry - I emailed you about this, but just wondering about map5. Is it a matter of further testing, or it you think it's too aggressive for E30? Or are you just trying to address IAT before additional map updates?
Is anyone else using their JB4, just curious because there was a lot of conversation before beta units went out, and it's been kinda dead since. I know once it goes live it will generate more discussion, but kind of surprised the stinger is getting more interest then S4 crowd. |
We collectively spend some time daily on the S4. Right now only maps 1-3 are well tested.
There is a higher boost map5 programmed but not tested across various conditions. You can experiment with if you want. Worst case is likely a CEL you can clear. Grab a log or two on E30 map5 and lets see how its working for you. |
1 Attachment(s)
Here's a log from tonight on map 5, doesn't really see more boost as far as I can tell, but it seems like it likes the E30. |
Around 30 BETA S4 systems out.. Most just email in to George or myself if/when they need help. Log looks good to me!
I deal with a local S4 beta customer weekly. Terry also has his own S4 that I see him work on a few times a week. The S4 JB4 beta is a huge difference in performance over stock.
Just installed a beta unit yesterday. So far so good. With 93 octane, which map has most of the other beta users settled on?
any updates?
Running Map 3 without any codes until today. Had to reinstall the unit for an unrelated visit to the dealership for tire insurance issues and during a stop and go traffic I suddenly got a “drive system Malfunction” on my gauge cluster.
Stopped and deleted the code with obdeleven (forgot what the code was) and then I got another Code on the way home. Not sure what’s causing the codes. George thinks it’s the IAT bug. The second code was P007A00, “charge air cooler temperature sensor bank 1.” |
Read codes via the JB4 itself, but if the code didn't reduce power or do anything, and disappeared when you restarted the car later, then yes it's the IAT bug we're hunting down in the SENT signal channels.
1st code - 8A4D 2nd code later - 8176 |
I've gotten the 8A4D error a couple times as well but only when I was in reverse!
3 Attachment(s)
Return of fault codes.
Yep - same error as me and same message on the screen. George mentioned they have a fix and are just figuring out how they are going to package it up for us as an update.
Guys we looking for a tester with a S4/5/SQ5 in Lexington KY specifically . If you in that area drop me a email.
