-   Mercedes C250, C300, C43, AMG (https://www.n54tech.com/forums/forumdisplay.php?f=38)
-   -   C63 JB4 Dyno and Logs (https://www.n54tech.com/forums/showthread.php?t=57954)
e92carlos 05-11-2019 05:22 PM
7 Attachment(s)
I got a chance to put my C63 on the dyno today. Overall pretty happy with the outcome. See below for logs and dyno sheet.
MAP 0 and 2 runs were done on 93 Octane.
MAP 5 was done on e30.
Best run was 531WHP / 624WTQ
Looking forward to installing intakes whenever they are ready.
https://i.ibb.co/fk5BLt2/dynorun.png
Any changes suggested based on my logs ?
Thanks,
Terry @ BMS 05-11-2019 08:45 PM
Not bad! Have a BCM installed yet on this? That lets us offset the wastegate dutycycle and push boost a little higher.
e92carlos 05-11-2019 08:50 PM
No BCM yet, how much more much can the stock turbos put out?
Can it break 600’s on stock turbos and fueling?
Payam @ BMS 05-13-2019 10:23 AM
Just emailed you, looks good!
e92carlos 05-13-2019 10:32 AM
Thank you sir.
BimmerFan 05-14-2019 09:26 AM
That's nice. What is BCM?
Edit: Never mind. Boost Control Module. It says it's not available yet on the Website and no installation instructions for it. Thanks.
e92carlos 05-14-2019 09:29 AM
Thanks,
Boost control module.
Payam @ BMS 05-14-2019 10:49 AM
We have about x10 of them out. We'll put it up on the site soon.
That's mostly for people with larger turbos, methanol, or running racegas and want every bit of power they can get :)
BimmerFan 05-14-2019 01:44 PM
Roger that!
LessIsMore 08-27-2019 09:56 AM
Thanks for posting the logs and dyno sheets. Looks great!
Any plans for an intake/filters? Would.love to see before and after with it on map 5.
e92carlos 09-11-2019 03:48 PM
Planning to go Pure 900ís soon, so i will probably be selling the Jb4 and going the reflash route.
LessIsMore 09-11-2019 08:10 PM
Why? JB4 works with flash tune. No need to give up the boost by gear, logging, etc. Plus if BMS hold to their promise, next firmware update should have good safety features built in (protect against lean afr, overboost, low fuel pressure, etc.) that flash tunes cant do.
Terry @ BMS 09-12-2019 06:07 PM
Awesome turbos! You're going to still need that JB4 for logging, safety, fine tuning, boost by gear, WMI/PI control, etc, etc!
Terry @ BMS 09-12-2019 06:08 PM
+1
I've got the latest firmware here if anyone wants to help test it. :)
ezatnova 09-14-2019 09:05 AM
+1
Oh man, thatís exciting! Any hints as to whatís in it?
Iím sort of tempted to try it out, but also a bit scared to do so since Iíll be maxing the car out at the roll race tomorrow. If something isnít quite right....not good.
