-   Support & Log Review (https://www.n54tech.com/forums/forumdisplay.php?f=44)
-   -   PureStage 2 Log Review (https://www.n54tech.com/forums/showthread.php?t=62333)
Joelkswagen 06-15-2020 02:12 PM
1 Attachment(s)
Hi Folks, looking for some feedback on the attached WOT pulls. Just starting to tune my N54 PureStage 2 setup, with the goal of utilizing map 6 JB4.
Two 2nd gear pulls and one 3rd gear pull in the attached CSV, JB4 Map 2. I have hidden most of the irrelevant rows. Trying to decide if things look healthy enough start cranking up the boost beyond just the JB4 Map 2 + Pump BEF Flash I am currently running. Fueling somewhere between E30 and E40 right now.
Things that stand out to me:
-Please take a look at the 6 cylinder timing. 2nd gear pull has some timing pull in cylinder 3-6.
-Trims tap out at 50 for short period
-Is an average ign of 4.4 high? Seems like it with just 17 lbs boost and E35. I feel like I have seen lots of people with similar setups, and with ign avg of 0-ish.
I have very new spark plugs gaped .21, and compression is pretty good/even. Not sure what to do in order to remedy these few issues. My car has 150k miles on it, so I want to make sure things are looking good before I push anymore power.
Car: N54 2008 135i
PureStage 2 DD
VRSF Silicone Inlets
Jb4 G5 + Pump Gas BEF via MHD
Fuel-it Bucketless Stage 2 LPFP
BMS Catch Can
7" VRSF Intercooler
DCI
VRSF Dwnpip
Dave @ BMS/Fuel-It! 06-15-2020 09:34 PM
Plug gap.. 21, or .021? Are these colder plugs?
Joelkswagen 06-16-2020 10:17 AM
Hi Dave, .021 I believe is the correct measurement. They are the step colder NGK, the ones sold by N54 tech for this application.
Dave @ BMS/Fuel-It! 06-16-2020 11:28 AM
Your log is extremely long.
Can you get me a cleaner log, all the empty cells of just cruising have 0 value for this given need.
3rd gear, 2k-Redline, WOT, traction off. Shift to 4th, end log
Joelkswagen 06-16-2020 11:49 AM
1 Attachment(s)
Sorry about that Dave, when I uploaded originally I had the unecessary stuff hidden, guess that didn't translate in the upload.
I have deleted the unnecessary cruising data. Now it shows a 2nd gear pull followed immediately by 3rd gear pull, and then another 2nd gear pull. Hope this is usable, I have hardly any time or space to run additional logs right now unfortunately.
Dave @ BMS/Fuel-It! 06-16-2020 03:28 PM
Trims do look a bit close to maxing.
You could run e40 and switch to the hybrid e85 flash.
Joelkswagen 06-16-2020 03:35 PM
If I do that would I still be able to run pump gas in the tank and revert back to map 1 on the jb4? There are times I do not have E85 access so being able switch it up on the fly is important.
Dave @ BMS/Fuel-It! 06-17-2020 12:54 PM
Realistically you’d want to stick with the pump flash if that’s the case.
That or keep a tablet etc in car
Joelkswagen 06-17-2020 01:15 PM
Thank you! One final question then, does anything about the log look dangerous or indicative of hardware needing to be replaced to run the current tune level I am at? Like you said I should probably play with the tune, but I am generally happy with the power now, just with JB4 Map 2 and pump BEF.
I guess I am not knowledgeable enough to know what the maxed out trims could really mean, or if the timing pull on different cylinders is at a dangerous level. Its been hard for me to narrow down because I think the LPFP and HPFP are holding up, compression is even on all cylinders, and plugs are new and gapped per recommended.
Again, really appreciate your knowledgeable eye.
Dave @ BMS/Fuel-It! 06-17-2020 02:21 PM
Just keep an eye on them, and if you ever throw the trimming control codes.
Overall nothing jumps out to me as dangerous
