-   N54 (https://www.n54tech.com/forums/forumdisplay.php?f=3)
-   -   Methanol blend (https://www.n54tech.com/forums/showthread.php?t=55053)
naoaki 09-16-2018 04:38 PM
Methanol blend
Hey, guys. I thought, 100%What is the merit of using methanol?I guess the cooling efficiency is higher for 50:50 and 70:30, but what? Because the moisture does not enter merit, it feels like a problem such as corrosion does not occur.I appreciate all the responses in advance.
Payam @ BMS 09-17-2018 05:03 AM
I use 100% all the time.
Nanometer 09-17-2018 11:16 AM
I use 50/50 to 60/40, to reduce risk of fire.
naoaki 09-17-2018 04:51 PM
What is the merit of 100% methanol? Does it improve output from 50:50?
as3.0cl 09-19-2018 04:05 AM
i use 100%, no mixing. Using this mostly on recommendation from Trebila and his tune.
I see AIT drops at or below ambient
codesx 09-19-2018 09:21 AM
Higher Meth % would be required with higher boost and more advanced timing.
Presumably, you need to log and see if there are any knocks, if so, higher Meth % would be required.
Some run 100% because they need to (boost levels) and others do it at lower boost, just for the insurance factor.
I intend to start at 50/50 and log. Will go up to 100% or whatever is required to ensure 0.0 knock at 17 PSI. (this is simply my target)
Uneducated Comment: I believe water would have a better cooling impact, though Meth would certainly help too. I'll be testing this for myself soon enough.
naoaki 09-19-2018 06:52 PM
I am using prometh direct port system (using 7th injector), but it seems that there is no problem at 22psi with a hybrid turbo at 50:50 blend so far so far.
Many people are using 100% methanol, so I was wondering what kind of change there is.
hi rpm 09-19-2018 07:03 PM
I did a lot of reading and the gist is that water is better for reducing cylinder temp (thus knock), meth is better for reducing intake air temp, and only methanol counts as fuel. If you need as much fuel as you can get, 100% meth is appropriate. Otherwise unnecessary IMO.
naoaki 09-19-2018 07:18 PM
100% methanol has the effect of additional fuel? Thank you for teaching me. It seems that 50:50 is more advantageous for cooling effect and knocking prevention. I also try both logs.
hi rpm 09-19-2018 07:59 PM
100% methanol is twice the fuel vs. 50/50 meth/water. Makes sense right?
naoaki 09-19-2018 08:16 PM
I think that it is more advantageous to run 100% methanol than you think from your opinion. You seem to have a wealth of knowledge and experience with methanol. So it will be helpful. It was troubled because it became difficult to set after making it a direct port system.
angelo_E82 09-20-2018 08:35 AM
has anyone here broken a throttle body running 100% meth? I ran maybe 5-7 gallons of 100% VP M1 before my throttle body was cooked. I am injecting through the chargepipe.
naoaki 09-20-2018 06:28 PM
I have been running meth for over a year at 50:50, but the throttle body has not broken down. Is not it a coincidence that 100% methanol seems to have no adverse effect on the throttle body?
FEDE/E92 09-20-2018 07:13 PM
There is no way methanol can ruin, brake a tb
