-   Honda Civic, Accord, and Acura Turbo (https://www.n54tech.com/forums/forumdisplay.php?f=40)
-   -   Best items to log? (https://www.n54tech.com/forums/showthread.php?t=67008)
87GN 11-18-2021 08:52 AM
Best items to log?
Hi. I'm fairly new to the forum. I have a 2021 Accord Touring 2.0T. What are the best parameters to setup for the logs? I know you can see them all on the spreadsheet. Which gauges do yall run for live monitoring on the app? I've read all 27 pages on the Honda forum. I'm trying to get up to speed on this car. I'm not new to turbo cars. I've played with my GN since 2003. It's far from stock. I understand turbo tuning basics, but now I'm trying to self educate on Honda 2.0T. Thanks!
Payam @ BMS 11-18-2021 10:35 AM
I usually keep the following:
Map
RPM
Boost
AFR
IAT
Fuel pressure
Cannon @ BMS 11-18-2021 10:37 AM
JB4 automatically logs all parameters.
87GN 11-19-2021 06:40 AM
Thanks for replies. I know all parameters are logged. When looking at log graphs, which ones are most important? The graphs can get messy when too many parameters are added. I usually have ones Payam suggested on the live monitoring. What all items are the best to be displayed for the log graphs? Thx.
Payam @ BMS 11-19-2021 10:07 AM
Depends what you're trying to look for but I usually just click pro view on the top right corner and it gives me everything I need. However, not all parameters will populate I.E. AFR2 since these cars only have 1 AFR bank to read from the other is for V6/8 cars with dual O2 sensors.
Terry @ BMS 11-28-2021 09:47 AM
Boost, timing, AFR, and ign2 which is the Honda knock control value.
87GN 12-11-2021 01:06 AM
Thx.
