-   Support & Log Review (https://www.n54tech.com/forums/forumdisplay.php?f=46)
-   -   Map 2 Log Check Please (https://www.n54tech.com/forums/showthread.php?t=56984)
JDARCO 02-27-2019 10:58 AM
1 Attachment(s)
Recently installed CG 200cel ********, wanted to have someone take a look at a log. I noticed Iím not getting 100 throttle opening, not sure whatís going on there. Waiting on the back end flash so just mainly want to make sure the car is healthy.
Log is on 93octane, also have mid-pipe and BMS intake installed.
Thanks,
Payam @ BMS 03-01-2019 12:42 PM
1 Attachment(s)
Looks pretty good. Throttle closure is cause of the **, but that's normal it's only to regulate boost in the beginning. Set FUA to 10 and get another log.
JDARCO 03-03-2019 12:43 PM
1 Attachment(s)
Thanks Payam, new log is attached with revised settings.
JBoe 03-05-2019 09:20 PM
looks better, but you should provide a log that's like your first. A nice long pull from about 2500rpm in 3rd or 4th gear. Your first log is the correct method. I've heard that ********* can cause the overboosting, but this is the first I've seen it so clearly. You may have to get the EWG wires to correct this.
Payam will chime in soon. Timing and trims look good from what I see. Just need to get boost more under control.
JDARCO 03-06-2019 06:36 AM
1 Attachment(s)
Hi Payam, as Jboe mentioned my previous log was a bit rushed. This should be cleaner. Let me know what you think.
Thanks,
Payam @ BMS 03-06-2019 11:30 AM
1 Attachment(s)
Not too bad, a little throttle closure in the beginning to regulate boost. Try setting FUA to 17. Lets see how that will do since you're in cold weather :)
JDARCO 03-06-2019 05:52 PM
1 Attachment(s)
Run at FUA 17 attached.
Just for my own education you said to try FUA 17 because itís cold here right now. Is this something I would adjust back to 10 as the weather gets warmer?
JDARCO 03-14-2019 02:31 PM
Bumping this for a reply, thanks
JBoe 03-16-2019 10:42 PM
1 Attachment(s)
Looks good to me... normal from what I can tell, but you're probably not able to support map 3 due to your fuel trims. For a better review, we really need to see a long 3rd or 4th gear pull. That's 2k rpm to redline.
It would look like this... (4th gear long pull into 5th)
