I installed it and the volume down does work. I'm on Firmware V31.6 and backend flashed the most updated E85 I8 bin.
However...upon use, it bogs out, and shows an SES light, then restarts the gauges as if I restarted the car. The car acts like it's stumbling, then when I let go of volume down, it doesn't take off as one would guess. I'm in 80-degree Fahrenheit weather. If I don't use it, the car acts normally. Do I have to patch the .xdf to the .bin I'm running? |
Assuming IAT is dropping when you press the button next you need to modify the flash file per the first post. If they have been modified then include a log of attempted use so we can see if anything stands out.
Will this become available for 335is DCT?
Terry how will this work for the guys running nitrous on a window switch?
We don't suggest or support nitrous use for the N54. And I certainly would not use it with an anti-lag setup.
Terry, I re-read the first post. I just purchased the antil lag, I have BB for flashing. I do not know how to modify the files like you stated. Is there going to be an updated flash to be released in the future for those not as skilled as you?
Thanks in advance, Matt |
Check the BB flash thread for the updated files.
Ok, so if i load the E85 flash i will be gtg?
I thought you had to update to the latest flash AND modify the files too. |
Temps don't go down at all and I'm using the IJEOS E85 PI MHD map from 9/13, which I verified with TunerPro has the necessary changes.
However, when I switch to the 23k chip, the temp automatically dropped without doing anything. So Terry is sending another chip to see if that's the case. Quote:
Hey Terry,
I'm sure most people who use this, wont be running map 5, however just in case have you factored in the usage of this, and excluded the time spent with button depressed from the average ignition retard calculation? If not, would this negatively impact the map 5 learning targets? Also, all the logs i've seen have the timing zero'd rather than showing the true negative timing. Can the logging capability be expanded to show actual timing retard? |
You'll be using this below 4000 rpm mainly and map 5 won't learn at such a low RPM but it's something to keep an eye on.
No plans to change the logging to show the actual negative values. |
Anybody wanna make a quick buck who's in NJ and can install the proper flash and cable for me ?
@blisstik I was trying to work out the changes for the timing drop through tuner pro. Can you post the 3d map comparison you see through tuner pro? Terry thought I may have a problem with the xdf I was using but I used the xdf provided in the 1st thread. Bit confused so could do with a pointer to get me on track with what I am looking at.
Ok so a little cooler in Boston today and on cold start and for the time it took to get my IATs up, it seemed as though it was pulling timing. Weird since it was in the high 50s. Another odd thing was i assumed this only worked on wot and it was working on part throttle as well. By the time I tried to log it, wouldn't you know it stopped happening...
On cold start the DME pulls timing to warm up the cats, etc. As long as IAT is over 38f degrees then the IAT compensation tables are ignored as currently implemented. |
1 Attachment(s)
I thanks Terry ;) I tested today anti lag. Woooooooo :happyCar is like aircraft:burnrubber:
is so good or bad ??? |
Record another log or two of you using the feature.
I have anathor timing this log ...
Ok Terry .i recorde anathor log |
