Hello,
I just purchased a 2016 GTI S and found out it had a JB4 installed after I purchased it. I have no way to get in contact with the previous owner. I ordered a cable and drove for about a week not knowing what map I was running on. I was just able to get plugged in today, and it appears that the car was on Map 2. I'm concerned because I know that the car was not recently filled up on 93 octane as it is not available in my area. Is there anything specific I should be worried about? I'm kind of bummed it was set to Map 2... Should I just set it back to Map 1 for now? I'm also trying to get the firmware updated. Is this the correct page for my vehicle? Thanks! |
Hang ten on the firmware update. We putting something new up this week. Map 2 with 91 wont cause any damage. In cooler weather most cars run fine with it, worse case scenario the ECU retards the timing and power delivery is not a smooth as it should. |
Okay thanks for the quick reply! I took in on a run set to map 0 and it feels a lot slower. Now I understand why this car felt so quick when I took it for a test drive.. Because it was already on map 2! I'll run in map 1 this week and check back here for the firmware. |
Oh I have one more question.. I noticed some values are very high compared to the example video. Here's a picture of them - JB4 Settings.png - Google Drive Do I need to adjust any of these settings for safety? Such as the Boost Safety? Or are all of these values only applicable when Map 6 is active? Thank you! |
Might also add a new map that will be map 2+ for guys that don't want to use map 6 and log. |
ok.... waiting for you George ;)
2 Attachment(s)
Hello and greetings from germany. I drive a seat leon cupra 300 sc handshifted with 14tkm on it. I just bought jb4 from CFD. The car works fine with jb4 but i have some issues.
I drive the car with map6 and a custom map with 22psi max boost falling down to 17psi near 7000 rpm. Fol is on 45 and 25psi is boost safty. I drive euro 102 octane with another turbo inlet and outlet, rest isnt tuned. 1. In 4 gear i dont have the full power :shrug in 5 and 6. gear all is fine and the car has full boost. asr (dsc) is off. 2. In 6. gear i have a boost drop near 4000rpm it feels like the diverter valve is hanging or something else. |
Hi, In both the logs at 5000 for example you making nearly 19psi, in the log of 4th gear you getting it to higher rpm which you not seeing in the other log so it seems its dropping more than 5th and 6th. There is quite a bit of taper of the boost so you can raise it more at higher rpm if you comfortable. Not sure what the drop out is in 6th. Does it do it every run? |
No its not every time its only sometimes and it feels like a lag or hanging something. Maybe its to much boost for the recirculation valve? Because at that point im nearly maximum boost.
Which of these values are correct? Currently, my GTI is stock aside from a drop in filter and I want to start from the "shipped with" settings as a benchmark. I JUST updated the firmware and see now that you mention something new is coming, I'll just grab that one when it does though. I'm stock DSG/93 octane with Map 1 if that's necessary information. Thanks for your help George! I've heard a lot of great things about the service you provide! |
little question for you George, what do you recommend me for a water methanol setup for my golf R to run it with the Jb4?
You can price the kit here: http://www.burgertuning.com/meth.html Step 1 select the tank you want, Step 2 we recommend the BM7 nozzle and Step 3 is the rest of the kit. To get a shipping quote do the first two steps of the check out process. Besides this you will need to get a throttle pipe with a meth bung from another vendor as well as a tap a fuse if you don't plan on cutting wires. |
Thanks so much for helping with this George! |
Update on new firmware??
