-   N63, N63TU (https://www.jb4tech.com/forums/forumdisplay.php?f=57)
-   -   Low AFR after 3.5 TMAP Install? Logs attached (https://www.jb4tech.com/forums/showthread.php?t=65210)
Yo_Holle 04-29-2021 03:34 PM
4 Attachment(s)
lowest Afr i seen were 11 but now dipping into 9 after tmap install. i changed the tmap setting to 1 and saved settings. can someone check my logs?
Steve @ BMS/Fuel-It! 04-30-2021 09:26 AM
Not sure why it's running that rich...it's doing it on map 4 when the JB4 is in bypass as well. :(
Yo_Holle 04-30-2021 05:14 PM
may just be my car, i could hear exhaust pops on the stock car. anything i should look for?
Also i was thinking about the bcm connections, would that be a benefit for me to install later?
Steve @ BMS/Fuel-It! 05-03-2021 10:40 AM
To run absolute maps you will need them.
