-   General Tech Support, Tuning Advice, Logs, and Help Me Posts (https://www.n54tech.com/forums/forumdisplay.php?f=35)
-   -   Can't go higher boost (https://www.n54tech.com/forums/showthread.php?t=54895)
p0wyangz 09-06-2018 09:27 AM
1 Attachment(s)
No matter which map I am in I can't go much pass 11psi. Wedge bef tune.
Terry @ BMS 09-06-2018 10:16 AM
Then you have an issue with your single turbo solenoid, wastegate, line routing, etc.
Step 1 is to put it on map1, turn ign on, engine off, press gas pedal down, check if solenoid is clicking.
