-   N55 (https://www.jb4tech.com/forums/forumdisplay.php?f=16)
-   -   F Chassis N55 JB4 (https://www.jb4tech.com/forums/showthread.php?t=18588)
Abear 07-29-2014 07:27 AM
Originally Posted by ghostchili (Post )
Terry,
Any luck using your magic on a stable map 7 with a 40-50% E85 mix?
Map 5 with the EWG harness, ******* DP, & intake is impressive..But I'll never be satisfied unless I blackout under acceleration so I want more!!
Haha, I think youre in the wrong car line if you want black out acceleration. The guys at UGR may be able to sell you a TT Lambo that will get a little closer to that goal though, hehe.
Terry @ BMS 07-29-2014 08:23 AM
Terry,
For higher power levels look in to meth and/or unleaded racing fuels.
ghostchili 07-29-2014 10:51 AM
I can get race gas 1 mile from my house. It's 110 octane leaded obviously. To use map 7 with my EWG harness. What ratio should I use?
If that doesn't do Ill get the TT lambo you recommended!
FC4 07-29-2014 11:15 AM
Wouldn't run leaded gas in these cars unless you wish to destroy your 02 sensors. 100-101 octane is typically as high as it gets unleaded.
Terry @ BMS 07-29-2014 02:44 PM
Unleaded only, IMHO! I'm not a Lambo guy. But if you want to move up test drive the new M3 and M5. Both fly with tunes. :)
ghostchili 07-29-2014 04:29 PM
M3 next! Iron out the kinks first.
Hellraiserharris 07-30-2014 12:07 AM
Originally Posted by sonystyle02 (Post )
I think this only swaps maps when you're in ACCY on mode (engine off). It would suck to be on a map and kicked into JB4 off if you were in the middle of driving and turning down the volume.
I'll let the experts chime in here.
It does it when the engine is on...it takes a while to reprogram your self from holding the volume down button to long when adjusting the radio.
Pixmixa 07-31-2014 12:44 AM
Absolutely. And when someone else drives the car it will happen for sure.
To prevent misuse it would be helpfull to change the activation process. Maybe long time down button and shortly up for map 0 and long time down and two times up for the other map or something like that.
Kongen71 07-31-2014 01:21 AM
F30 JB4 stage 2 throwing any codes with c**less dp on? do we need to adjust anything?
Abear 08-01-2014 01:35 PM
It doesnt show codes.
copperman05 08-06-2014 03:28 AM
So now FF wires are required to run an EWG car with EWG harness despite whether we are running E85 mixes or not? Its mentioned on the first page of this thread but I haven't seen it discussed here or announced anywhere...
sootyvrs 08-06-2014 03:57 AM
I currently have ewg harness without ff wires on map 5 using 99ron fuel. No plans for mixing ethenol. What are the disadvantages of not using the ff wires in my case?
Will I encounter problems by not installing the ff wires?
alz0rz 08-06-2014 07:47 AM
That is exactly why I started this thread:
http://www.n54tech.com/forums/showthread.php?t=26059
Looks like some communication was initiated and now there is a statement that it is required to use the FF wiring with the EWG. For cars with an EWG, the JB4 EWG harness allows you to properly monitor the HPFP and as such finer AFR compensation. Without the flex fuel wiring tapping into the fuel rail sensor the logs of the HPFP will be incorrect (atleast on the N55...).
Terry @ BMS 08-06-2014 08:42 AM
Yes.
copperman05 08-06-2014 09:27 AM
Ok thanks, but nextime could we have it a little clearer than putting on one line at the front of a 20 page thread that tbo I wouldn't have read unless someone else had pointed it out to me.
If we need to be running the FF wires, we need to be told...
copperman05 08-06-2014 09:55 AM
Terry, there are a few of us running the JB4 with EWG harness over on babyBMW in the UK. A couple of questions have cropped up if you could take the time to reply please.
1.Is there any inherent dangers in running map 5 and the EWG Harness plugged in without FF wires and if so what might they be?
2. If we are not going to get the FF wires should we be unplugging the EWG harness?
F335 08-06-2014 12:40 PM
Why arent we getting any firmware updates?
Cybertronic 08-06-2014 12:45 PM
From reading the EWG post... its recommended that cars with a EWG should run the new 2.6EWG firmware, regardless if you have the EWG and FF harness installed.
Terry @ BMS 08-06-2014 12:51 PM
F series firmware updates are posted regularly!
F335 08-06-2014 12:53 PM
Not for us with pneumatic wastegates :cry:
Terry @ BMS 08-06-2014 12:54 PM
There have not been many changes on that front recently. But our 2013 335 is pneumatic and it's never far from our mind. :)
Newguy123 08-06-2014 02:34 PM
when are we getting feedback on jasons PURE gains?
Terry @ BMS 08-06-2014 03:38 PM
I was hoping to do some dyno work today with it but other unrelated projects cropped up. Probably Friday before I get back to it.
Cybertronic 08-15-2014 09:48 AM
Any progress on the start-up bug fix?
435ant 08-17-2014 05:43 PM
So, in short, does it mean?
either
i.) You can live without any harness (EWG, FF) - map 1 is recommended;
or
ii.) Connect both EWG && FF wires at the same time - map 2 is recommended unless you are a Pro who understand a lot.
