-   N55 (https://www.jb4tech.com/forums/forumdisplay.php?f=16)
-   -   F Chassis N55 JB4 (https://www.jb4tech.com/forums/showthread.php?t=18588)
Terry @ BMS 02-08-2022 04:22 PM
Could have a wrong setting, can't check that until you attach a CSV.
mbanks21 02-08-2022 04:41 PM
Can I email it to you from the app directly?
Steve @ BMS/Fuel-It! 02-09-2022 11:51 AM
Email it to yourself, save it, and upload it here. ;)
mbanks21 02-09-2022 03:41 PM
1 Attachment(s)
Hope this works. 2015 335, jb4 w mhd flash, flex fuel, ewg harness, 3 gallons of e85 not sure what else you need to know.
PID 20
FOL 70
I'm ignorant to a lot of this stuff so thanks in advance
Steve @ BMS/Fuel-It! 02-10-2022 11:56 AM
I see you have them but are your EWG wires connected? Also, set your user adjustments back to the default values, enable option 6 since you have a BEF loaded, and then do a proper log on map 5.
To properly evaluate the tuning, we'll need a full throttle JB4 log from 40-90mph on a safe private track.
F Chassis N55 JB4 - N54Tech.com - International Turbo Racing Discussion
mbanks21 02-10-2022 02:43 PM
1 Attachment(s)
Hopefully that looks better and yes ewg is hooked up
Edit - just got drive train error again.
Steve @ BMS/Fuel-It! 02-11-2022 11:06 AM
Did you set FF to 50 and it already worked its way back up to 150?
Also, try a log on map 1...I want to see what that looks like.
mbanks21 02-11-2022 02:43 PM
1 Attachment(s)
Yes FF was 50. Map 1 attached
mbanks21 03-02-2022 05:23 PM
Any other suggestions? Still getting drive train error no matter what map I'm on. Started after last update last month
Steve @ BMS/Fuel-It! 03-03-2022 11:45 AM
That's a really short log but looks pretty normal. What code are you getting with the DTM?
I'm not sure what version of rev 18 you have but there is a new beta version 19 available...try uploading that.
mbanks21 03-03-2022 12:13 PM
Sorry DTM? I get codes codes 123511 and 120408 which is sluggish wastegate and reduced power I believe.
I was on whatever the latest version was ~4-5 weeks ago but when I get home Ill see if there's a new one and try that. Thank you for your time!
mbanks21 03-04-2022 07:08 AM
If I get the drive train error while in map 4 can we assume that the issue is not jb4 related?
Steve @ BMS/Fuel-It! 03-04-2022 11:42 AM
DTM = Drive Train Malfunction
Try putting the stock harness back on the Wastegate and see if that resolves your issue.
Thatslow135 03-05-2022 09:22 AM
Don’t mind me, I just need 5 posts to post links! Sorry
Steve @ BMS/Fuel-It! 03-06-2022 08:03 PM
What do you need to post a link to? We don't typically click on links.
mbanks21 03-11-2022 05:00 PM
Put the stock ewg harness back on and so far no issues. If this solves the drive train issue does that mean bad waste gate or could it be a harness issue?
Motorsport_buddy 07-27-2022 02:33 PM
Can i run map 2 without any other mods such as down pipes? I have high quality 93octane available in my region but want to keep the car as stock as possible
435gc 07-28-2022 04:27 AM
At a minimum you need an upgraded charge pipe. The stock one will blow.
Terry @ BMS 07-30-2022 05:16 PM
+1 a BMS chargepipe is a good proactive upgrade on these if the plan is to run higher boost levels.
