-   Support & Log Review (https://www.n54tech.com/forums/forumdisplay.php?f=44)
-   -   New Log, PI not working (https://www.n54tech.com/forums/showthread.php?t=57689)
lowelementstar 04-23-2019 10:43 PM
1 Attachment(s)
I just recently installed the pi with 750cc, stage 3 fuel pump and the jb4 pi controller. It seen like the port injection is not working. Running the st e85 pi ts thr map. Here a log, let me know know what going on.
Dave @ BMS/Fuel-It! 04-23-2019 11:02 PM
Are you getting a meth trace line?
Double check wiring on the controller itself / make sure menu 8 is set to “0” too (unless your MT using NLS/step)
lowelementstar 04-23-2019 11:58 PM
I see the meth on the graph but it just straight across line. I'm pretty sure the wiring all correct. Yes menu 8 is on 0. Fuel bias 50, meth scale 99. Do I need to setup anytime like trigger, etc.? Yes I do have a new anti lag chip in it.
Dave @ BMS/Fuel-It! 04-24-2019 10:09 PM
If all wiring is correct, & the correct BEF is flashed- you should be ok.
Double check wiring / all connections next.
lowelementstar 04-26-2019 01:46 AM
1 Attachment(s)
Dave, on the log I can see the fuel enrichment but no meth trace. What could be wrong?
Dave @ BMS/Fuel-It! 04-26-2019 06:29 AM
If meth trace isnít present - itís a wiring issue
