1maudiz 10-15-2021 08:23 PM
UPDATE
Switched from map 5 to map 2 and now I’m probably going to need a motor ����
Ran great missfired and died took plugs out saw the tip to one was broke off changed plugs and now my whole top end is knocking badly 49k miles on the car
Trying to find a stock down pipe and send it to Audi to hopefully get warranty work done … PRAY FOR ME GUYS THIS SUCKS!!!!
santiagoafull 10-16-2021 08:11 AM
Originally Posted by 1maudiz (Post )
Switched from map 5 to map 2 and now Iím probably going to need a motor ����
Trying to find a stock down pipe and send it to Audi to hopefully get warranty work done Ö PRAY FOR ME GUYS THIS SUCKS!!!!
Car? S3? year?
George @ BMS 10-16-2021 08:29 AM
Some misfire codes require them to be cleared a few times. You can try disconnect the battery for a while.
If you taking it in dont clear the codes.'
Where the plugs stock? We have never seen tips come off on stock plugs. They can burn the tip away after long use but dont fail.
1maudiz 10-17-2021 01:02 PM
Update
Car is a 2015 A3 With the 2.0 and yeah stock plugs Iíve personally never seen a tip come off a plug too! Cleared the codes no more codes for the missfire,
I can upload a YouTube vid if you want to see the sound itís making
it itís kinda crazy for only 49k
Question for you guys when I take this car to Audi for warranty work should I keep the new plugs I put in and keep quiet that a plug failed?
Say ďcar was missing so I tryed new plugs and noticed that it was making a sound tooĒ? (Having the girlfriend take the car in)
My biggest struggle right now is finding a used stock DP
Right now the car had a ******* down pipe and I would think that Audi would flag the work and not cover the issue if they see the ***************
George @ BMS 10-17-2021 01:29 PM
Note sure about the plugs. DP would be a issue.
1maudiz 10-18-2021 10:40 AM
Yeah thatís what I figured thanks hopefully I can get this fixed soon till then :burnrubber::burnrubber::burnrubber::burnrubber:
Hally83 11-24-2021 02:34 PM
Hi George, do you support the new 2021 Mk4 Skoda Octavia RS Australian spec? It’s got the EA888.3 with IS20 not the garret turbo. I’m picking it up tomorrow.
George @ BMS 11-24-2021 03:37 PM
Originally Posted by Hally83 (Post )
Hi George, do you support the new 2021 Mk4 Skoda Octavia RS Australian spec? Itís got the EA888.3 with IS20 not the garret turbo. Iím picking it up tomorrow.
The Group 2 unit will work on it. Will be best to email some logs to me once its up and running.
We missing a few OBD parameters on it that will will add on a future firmware update that will be specific to those motors. We have done a few MK8 GTI's already that have the same new/old motors in them. It seems South Africa also got the same spec with the IS20 and I managed to get one in and test on it.
santiagoafull 11-25-2021 08:20 AM
Excellent George!
What would be the updated list of cars that support the JB4 gen3 "B"? Thanks in advance!
George @ BMS 11-25-2021 12:23 PM
Originally Posted by santiagoafull (Post )
Excellent George!
We might confuse things by calling it a 3B as that is already a different motor that is fitted in the 140kw models.
We going to sell the Group 2 for the Australian and South African market as is from the site and then down the line create a market specific firmware for them so all the OBD channels will work. They seem to be the same as the MK8 R Euro spec so once we have solved those it will be easy to test as I am in South Africa and have access to the cars.
RPHD26 12-01-2021 09:32 AM
Hi, So I have a mk7 Golf GTI PP in the UK and have got an induction kit + Scorpion non res catback. Currently just been using map 2 with 99RON. Would a custom map 6 see better gains / drivability with these mods?
George @ BMS 12-05-2021 03:52 AM
Yes, on 99 we can run more boost than map 2.
Raks9201 12-13-2021 12:59 AM
2018 8v2 S3 Fuel pump not priming (Intermittent issue)
Originally Posted by Raks9201 (Post )
Hi George
I installed the jb4 in my Audi s3, I noticed after the install my car won't start sometimes with the first turn. Note I don't have the keyless option and have to physically turn the ignition. I noticed this happens intermittently and seems to only has happened on maps 3/4/6 & 8. It will just hang like there is no petrol, not the same noise you hear when the battery is flat. I switched into Map 0 this morning and I am waiting to see if it happens again.
Have you ever come across this fault before? If yes why and what is the solution?
Warm Regards,
Hi George
I think I prematurely agreed that this problem was rectified. After changing the fuel loop to 45 I still got the starter issues after a while. I then ran the car on Map 0 for around 2 months and the problem disappeared completely. After changing it to map 1 on the weekend everything thing ran fine initially until the same issue started again. It seems to start fine in the morning however after a short drive and stop, on the restart, it had a hanging starter like there is no fuel. Once I turned off and tried again it started again. Please assist me, I hate not having my jb4 on.
Warm Regards,
santiagoafull 12-13-2021 01:43 PM
George,
I just sold my S3. I bought a 2018 Audi A3 40TFSI (2.0T 190CV). Is it compatible with the JB4 GEN3 B that I was using in my S3 8V? this car has DQ381. The stickr on the box says: JB4-MQB-2.0-AWD and check box "other" says "B".
Thanks in advance George
George @ BMS 12-14-2021 05:41 PM
George,
You can run it in map 1. Dont connect plug C on the side of the intake manifold or the AFR connection.
santiagoafull 12-14-2021 06:14 PM
Sorry: I did not understand what I should NOT connect:
1) Plug C (intake manifold)
2) AFR wire.
Correct?
Dq381 I can't use map 3?
Thanks George !!!!
George @ BMS 12-15-2021 04:54 AM
2) AFR wire.
Correct?
Thanks George !!!!
Map 1 on Gen3 firmware is the same as map 3 on Gen3B firmware so that is the recommended map.
Map 4 has too much boost for this motor.
santiagoafull 12-15-2021 07:01 AM
Ok George.
To install: plug C not install? Sorry dont understand this
George @ BMS 12-15-2021 07:22 AM
Ok George.
No, that is not used at all and leave stock one in place.
danbfree 12-17-2021 06:32 AM
Hey George, Map 3 is fine with good fuel without the AFR wire on the 1.8, right? After buying from a Golf R owner I'm getting perfect trims, stock AFR's and no timing corrections. I'm hooking up the AFR wire later as he had the full AFR passthrough plug for MK 7.5 and my T fit connectors arrive later today, but these 2 pulls (trimmed to one chart) look good right? Not sure how to post links here, had to cripple it to post.
datazap . me /u/danbfree/map3?log=0&data=1-3-4-6-11-14-15-18-25-26-27-28
djdouglaslopes 02-02-2022 08:53 PM
Hi, I'm new here on the Forum!! There are some logs of my car mounted stg2 + JB4 turbo IS38 in the phase of adjustment with George!!!
https://***********/u/djdouglaslopes...=0&data=1-4-18
donJimenez 02-07-2022 10:56 AM
Is it running a little rich up top? Maybe why it's not reaching target. Great boost numbers.
djdouglaslopes 02-07-2022 11:15 AM
Hi, you're really right, it's a little rich up there!!!
I'm working out some details about the fuel mixture with George, in this log I have FUEL BIAS 100 between 2500 to 4500rpm, and 20 between 5000 to 7000rpm, and FOL at 50!!
About the turbo not reaching the target, we saw that the flash that is in the car's ECU, for sure, has the wastage setpoint modified, so it can't pour more than 20psi at high (6000RPM).
I'm still testing, because I'm having error 3A9F, and let's lower the FOL a little to 40!!!
GolfRBhoy 03-09-2022 10:34 AM
New Install Help/Advice Required Please
Hi, I've just installed a JB4 on my MK7 Golf R and have the app and can connect to the car. All is good so far.
I've emailed George to start the custom map setup and await a response.
In the meantime, what is the best map to run until I get the custom map?
Is there a list of the current maps and what they do for my car available to view?
What is the process for logging data? For example, should I drive the car in Map 6 then log a drive? I read somewhere you drive in third gear and log until it changes to 4th gear, but the posts I've been reading are quite dated and I really want the most up to date information.
THanks in advance!
donJimenez 03-09-2022 11:53 AM
I think post #1 is kept up to date with Maps and Firmware
JB4 for Gen3 VAG Group - N54Tech.com - International Turbo Racing Discussion
