-   Support & Log Review (https://www.n54tech.com/forums/forumdisplay.php?f=44)
-   -   JB4 W/ MHD BEF Boost Problem (https://www.n54tech.com/forums/showthread.php?t=58758)
GreenE92Matt 07-12-2019 04:38 PM
Hey guys. I live in Houston Texas where it is hot as balls. I just got my E92 335i back from a shop that did a turbo swap from stock to MMP 1K turbos. They also did relocated inlets and a silicone outlet. With that being said I myself did a MHD BEF Stage 2+ on the car and I am running it on Map 5. Some pulls go up to the full target 18 psi of boost but sometimes it gets limited to 10 psi then sometimes 8psi.. the pulls are done always the same.. a 3-4 pull. Could this be the JB4/MHD? Would it be a boost leak? Anyone experience this before?
Haynpunch 07-12-2019 05:51 PM
Post a proper log in the Support section
Rushan 07-13-2019 02:18 AM
You are running map5 on the JB4 with MHD stage 2? Not sure if I understand it correctly but for using JB4 in map 5 you would need the BMS MHD flash depend on you fuel rather than the MHD stage 2,
Except if you are using the JB4 only as passive and you switched your JB4 connections to run the 4/3 menu but I dont think you should also be on map5.
Anyways a proper log can show more details
Dave @ BMS/Fuel-It! 07-15-2019 12:41 PM
Odd / confusing.
Are you running JB4 + a BEF? or JB4 installed w. an OTS MHD Map?
Proper setup would be installing the latest / proper JB4 firmware & Then installing the HYBRID BEF for your new turbos...
I would start by double checking what you have installed currently & if it is not what i mentioned above- correcting / switching, and then posting a proper log in MAP 1
