-   N55 (https://www.jb4tech.com/forums/forumdisplay.php?f=16)
-   -   N55 EWG Please Help with electronic wastegate ! (https://www.jb4tech.com/forums/showthread.php?t=66255)
Monoid 08-18-2021 09:35 AM
Hey guys i own F30 N55 EWG and i have the following problem with my Electronic Wastegate.
I swaped the stock turbo with cutom fitted GTX3071 with cutom made manifold. After the turbo swap i tried to setup the correct postion of the wastegate actuator but from time to time i have limp mode with following message *wastegste out of tolerance* Also the car is a little laggy i have full boost on 3300rpm witch means that probably the gate is not closed fully and itís stuck open. My question is that is there anyway so i can set the correct position and how to do it if itís possible. I saw the big boost kit has a manual how to set the correct position for ewg but probably it wonít be a solution for me because they use different linkage on their turbo. Please give me some advice how to fix this stupid issue.
RVA_N55_Fan 10-11-2021 08:03 PM
a mechanical adjustment aided by using the ISTA+ diagnostic tool
