-   B58, B48 (https://www.n54tech.com/forums/forumdisplay.php?f=36)
-   -   m140i Log Check? (https://www.n54tech.com/forums/showthread.php?t=61993)
naughty140 05-14-2020 06:37 AM
m140i Log Check?
3 Attachment(s)
I would appreciate it if someone could take a quick look at my log. I know you guys are plagued with the same questions everyday, so I understand if it's tiresome.
I'm really keen to understand the logs myself, so if you could tell me what I should be looking out for, and roughly what it's doing to the car, that'd be great. (AFR, Trim & Target lines for example)
I installed the v15 firmware a few weeks ago. I just want to make sure everything is running OK. I'm pretty certain everything is normal.
Using map 1 for now, I'll knock it up to map2 and then 3 if the car keeps reacting positively. Running Shell V Power 97 octane fuel. Car is completely stock engine wise.
I've been running the JB4 since March 2019, but I deactivated throughout the winter as I don't push the car too often during those months it was running on the old firmware obviously.
I did 3 runs, I was going to post them in order, but I can't get the images to display via the insert image button.
I can also upload the log data if needed.
Payam @ BMS 05-21-2020 12:14 AM
Please attach the CSV file.
naughty140 05-24-2020 04:00 AM
3 Attachment(s)
Thanks. I'll attach them in order of the logs displayed.
Terry @ BMS 05-25-2020 07:32 PM
Octane looks a little shaky. This is v11 firmware. Update to v16 and grab another map1 log for comparison.
naughty140 05-26-2020 07:48 AM
4 Attachment(s)
Thanks Terry, sorry to waste your time.
I've just done two runs on the (hopefully) V16 firmware.
take a look if you get a minute.
Terry @ BMS 05-27-2020 10:37 AM
Looks much better to me here, try map2 next.
