George @ BMS 10-17-2019 02:33 PM
Originally Posted by s3s3s3 (Post )
I am experiencing what seems like a lot of misfiring/jerky acceleration on map 1, stock 2016 s3 with 98 octane. Can anyone help me out?
https://***********/u/s3s3s3/wtf?log...-9-11-14-18-19
I can see the issue. Your max boost 1st is set to 19 and with the new firmware its trying to cut 19psi from total on that gear. The way it works now is the value you punch in is the boost that will be cut. For stock first set it to 4 so you can cut 4psi in 1st.
George @ BMS 10-17-2019 02:38 PM
Originally Posted by ZuMBLe (Post )
What can the Fuel-IT with JB4 do on the VW platform? What are the possibilities?! It would be great if I could get the JB4 to add boost based of ethanol reading, or dial back boost etc.
We havent had much demand for something like this so havent really thought of what it would do based on boost. Assuming its something we would work on what psi add would you set per E10 of detected quantity?
i.e. If E20 is present add 1. If E30 is present add 1.5 etc.
ZuMBLe 10-17-2019 03:25 PM
I was thinking more along the lines of the JB4 looking for a E value which we can set to trigger Map 6. When the value is not met, default to another map (including 0).
I'll bet if you worked that out, you could sell Fuel-IT / JB4 bundles. The JB4 really shines on the VAG platform when ethanol is introduced.
ZuMBLe 10-17-2019 03:30 PM
Also, any idea if I would have an problems installing the Fuel-IT 5v kit on my 1.8 liter?
George @ BMS 10-17-2019 05:14 PM
Drop Steve a email at steve@burgertuning.com, he will know.
ZuMBLe 10-17-2019 08:05 PM
Nora2004 10-19-2019 02:54 PM
What are people's thoughts on how much we can push an is38? Right now I'm at +8.5 at peak which is producing 24psi, and tapering down to 20psi at redline, the thing moves out, however in the UK out temperature has dropped massively and I'm debating pushing a little more to take advantage!
Or am I at the limit for stock **?
sprinks 10-22-2019 10:08 AM
The fuel-it/jb4 combo with auto-adjustable map settings based on ethanol content would give the jb4 a new edge on other off-the-shelf options. There's nothing out there that compensates for fuel on the fly.
fescen9 10-25-2019 03:50 PM
Maybe a silly question but since the first post just says
Is this the right firmware for the 2019 GTI Mk7.5?
Also what do these codes mean?
3AE7
431A
George @ BMS 10-25-2019 04:55 PM
3AE7
431A
Oh those are the cars in my signature that I own.
Same firmeware is used for 7.5
The first fault we dont have a translation. If you do read it with another diagnostic tool let us know what it means.
Second one we see on most cars. Its a message that there is something stored on another module on the car. If all works fine then not a concern.
fescen9 10-25-2019 05:25 PM
Oh, lol, gotcha!
Firmware updated without error. Man does map 1 pull so much harder than stock, thanks!
Torque doesn't show anything. I bet those were the two codes that are thrown after pulling the battery (traction and something else right?)
Thanks again!
B.T. 11-07-2019 04:05 AM
Hi there.
Just recently I got done with the first round of modifications on my 2015 A3 which consisted of southward pipe without feline element, hybrid IS38 and JB4.
Since then I've been doing some logging to eyeball how things are going and I'm just not sure if what I'm seeing is . . . right?
Here are two logs. One on map 3 and another on map 6 with flat boost set at 26 PSI and safety at 28.
https://***********/u/usermcuserface...log=0&data=1-4
https://***********/u/usermcuserface...log=2&data=1-4
What I'm seeing consistently, no matter at which boost level or which map, is smooth-ish boost buildup, choppy "hump" starts at 3800-ish, hits the target at peak, drops (relatively) sharply at 5200-ish, then another choppy "hump" till 6500.
I suspect I might not be looking at what's important or might not have proper knowledge to interpret it, so here I am hoping to get some educated opinions.
George @ BMS 11-07-2019 03:51 PM
Originally Posted by B.T. (Post )
Hi there.
Best to email the logs through to george@burgertuning.com and I can have a look at what its doing. We dont use data zap so please send the csv files.
Nora2004 11-08-2019 02:43 PM
Quick one, feel bad bothering George all the time! What's the highest I can raise the FOL to? I'm having bad lean issues that I'm at a total loss at now tried everything, tonight I set FOL to 65, thinking 60 was the max we could go, and finally got a reaction from the fuel trim, first time it's changed in the last 4 weeks! So, is this ok, can I jump to 70?
George @ BMS 11-09-2019 05:09 AM
Thats what I am here for :) It can go up to 100 but you will start seeing fuel rail pressure faults (3AD2).
Nora2004 11-09-2019 09:24 AM
You really are a legend, never known such support from anywhere, just always feel guilty taking your knowledge and advice for free!
So I think I've definitely sorted this now, my trims were flat lining at 36 every pull which resulted in my AFR's leaning out when under peak boost at 23psi! I had my FOL at 55, changing this about didn't seem to change the trims at all, always pegged at 36!
Changed to 70 and every 4th gear pull since has been spot on, trim line follows the added boost line and afr's stay in the 13.5ish range as opposed to the 15-16 range! Yay!
Just to make sure what I'm thinking is correct, the 3ad2 code doesn't hurt anything? It only very occasionally brings the EML on and it doesn't bother me it sitting there, so I can continue like that?
Once again, thanks very much!
George @ BMS 11-09-2019 03:10 PM
The 3AD2 fault is caused from the JB4 over fooling the ECU into thinking the rail pressure is lower than it should be so it can hold more pressure. It doesn't mean that the pressure is actually low but the ECU perceives it as this. Its not something that can cause a issue though when triggering the light.
jb4998 11-22-2019 06:07 PM
So I uh... read a lot of this thread, and I'm taking in the information I can. However, I cannot seem to find any results searching on this.
Should I be concerned with the application randomly recording logs? When I'm driving around without logging turned on I often see a popup that a log has been recorded, and I see those logs in my log history. It's usually after a hard pull, I apologize if the answer is obvious.
jb4998 11-22-2019 06:44 PM
How are you measuring these issues?
Nora2004 11-23-2019 02:18 AM
The app has auto logging turned on by default, it will auto start logging when at 80% throttle!
jb4998 11-23-2019 12:06 PM
Thanks for the reply. Your replies and the random logging have caused me to look at my AFR. I'm not sure what this is supposed to look like, but I have read it is supposed to be about 14 at idle and this number drops significantly under boost.
What I can't explain is why my AFR is dropping randomly around 2500-3000 RPM... unless the drop is just instant as soon as 0.1 boost starts to show. I tried linking my logs, is the common website for is not allowed here?
George @ BMS 11-23-2019 03:39 PM
The AFR is rather complex on these cars so it would take paragraphs to explain what it needs to do in various scenarios.
When you on light throttle and normal cruising the ECU controls the AFR so there is zero concern. We just check on full throttle logs that all is good but so many years in on these models we rarely see issues.
jb4998 11-23-2019 04:23 PM
Thank you for the reply... I was wondering, can you use AFR to track a boost leak? The reason I ask, I notice after I fully let off the throttle after any decent turbo engagement the boost is hanging between 0.1-0.4, and this in turn is causing the AFR to stay low, around 3.x-4 until I get on the throttle again.
Is the 0.1-0.4 boost reading indicative of a boost leak? Is coasting around in gear at 3-4 AFR going to cause a rich condition?
I would send you the logs, but I have already sent you two emails in the last 24 hours, and I don't want to be that guy :)
salik990 11-25-2019 06:00 AM
is there option to check IAT2 as in pre-intercooler temp or intake temp, i think cobb accessport shows both IAT.
George @ BMS 11-25-2019 06:32 AM
The readings are both after the intercooler. On is pre throttle and one is in hte intake manifold. Hardly any variance in the two and in order to maintain logging resolution no point in adding the pre throttle reading.
