-   //M (https://www.n54tech.com/forums/forumdisplay.php?f=33)
-   -   Mods done JB4,BCM (https://www.n54tech.com/forums/showthread.php?t=56124)
RicksterF13 12-08-2018 07:18 PM
Mods done JB4,BCM
I installed my new plugs today and while I was at it I installed my BCM and reinstalled my tuner and added the jb4 bluetooth connection. I have some questions now. The JB4 wireless is connecting to my phone via the app. I'm not getting any readings though, so where might I have gone wrong? Plugged tuner in the same places as before, and BCM down behind passenger side charge cooler. Patched the blue wire from the wireless to the red wire of tuner box using supplied splice and plugged other end into tuner. Is that all? I can change from Map to map and it allows me to save existing tune and modify other parameters. Any info that would be pertinent to data logging is not present. I'm just in need of a little help. I'm one city away if it helps to see it.
Terry @ BMS 12-08-2018 07:27 PM
Is the OBDII in properly? JB4 log?
RicksterF13 12-08-2018 07:34 PM
ah ha that's it, that's what I'm missing. I don't have the obdII cabling. Where would I get that?
Terry @ BMS 12-08-2018 07:38 PM
It's part of the JB4 kit. See install guide for details.
RicksterF13 12-08-2018 07:41 PM
I had to piece mine together since i bought just the tuner at first. I likely don't have the full kit that I should have. I got all the other pieces separately
RicksterF13 12-09-2018 08:30 PM
Final question then Terry, can I purchase the OBDII cable I need?
