-   N54 (https://www.n54tech.com/forums/forumdisplay.php?f=3)
-   -   Stubborn tiny leak from this area on N54 motor (https://www.n54tech.com/forums/showthread.php?t=61699)
SDbboy 04-17-2020 01:49 PM
I've replaced the oil pan gasket, oil filter housing, and rear main seal and this leak persists. Has anyone experienced a tiny oil leak in this area?
https://smky.io/rmv0
https://smky.io/dTIB
rcpro88 04-17-2020 08:59 PM
Thats not the oil pan thats leaking. I'm not sure what the part is called but its kind of similar to the upper oil pan on my brothers VW.
RealOEM.com - Online BMW Parts Catalog
There is a diagram that shows the block and the lower piece that bolts to the block, then the oil pan bolts to that piece and maybe to the block as well.
iminhell1 04-18-2020 09:04 AM
That would be the bedplate/girdle what ever you wish to call it. The gasket there is injected. It's not something you really want tot try and fix yourself. To do so you need to remove the oil pan and then the bedplate and scrape (or chemical) remove the old gasket and then put it all back together and inject the new gasket (anaerobic).
This is where it's described,
11 21 505 Sealing crankcase lower section (N54, N54T)
SDbboy 04-19-2020 05:49 PM
Thanks guys. I will pas this info along to my mechanic.
