N54tech.com | BMW N54 N55 135 335 535 Turbo Performance Forum
bimmer335i07 bimmer335i07 is offline
Default USB install through the firewall. - 02-06-2010, 09:15 PM
Since there doesn't seem to be a DIY on here (or at least I haven't seen one). I made a short write up on how to route the USB through the engine bay's firewall into the passenger side footwell. Then after that you can just run it up into the glove box. I'm sure everyone knows how to get into their DME and into their fuse box in the glove, so I'll leave that info out. lol!
Disconnect the negative terminal to battery.
1. Inside the passenger side footwell, below the glove box. Use a T8 torx bit or T8 torx screwdriver to remove the 2 screws where the yellow arrows are pointing and let the plastic cover lay on the floor.
2. Go into engine bay to the DME box and unclip the plugs where the red arrows are. Every car is different because of options. So, mine might have more plugs than yours and some might have more or less than mine, but if you see plugs there, just unplug them. Don't worry about remembering which position it was taken out, it can only go back in one way. And it's all color coded, BMW FTW! lol!
(The reason for unplugging the plugs, is so that it'll make it easier to remove the plastic dividers later on.)
3. Pull out the rubber grommets where the yellow arrows are.
(This way, you can move the wires towards the headlights to give you more room to remove the DME, plastic dividers and the small plastic box that holds the DME.)
Once everything is unplugged and pulled out. Pull all the wiring harnesses towards the headlights and it should look like the pic below.
4. Pull the tabs where the yellow arrows are and remove the DME.
5. Pull the tab where the red arrow is to remove that divider.
6. Pull the tab where the green arrow is to remove that divider.
Once the DME and the dividers are removed, it should look like the pic below.
7. Remove the small box that holds the DME and the dividers.
Once the box is out, you'll see a hole where you will push the USB wire through.
8. Push the USB cable straight down, don't need to use a lot of force, just stick it down and you'll see it in the passenger side footwell. Just push it through probably about an inch or two.
(Don't need any type of hanger or wire.)
9. Go to the passenger side footwell in the middle and you should see the USB cable sticking out.
Once the USB is through, pull as much of it as you can and route it up into the glove box.
Once the USB cable is through, just go in reverse and put everything back. Once everything is put back together, plug the negative terminal back onto the battery and test to make sure everything is good. After running the USB cable through the firewall, you can follow Terry's instructions on the 2.0 upgrade.
That's it!
:D
There might be easier ways to do this DIY, but I found this to be the easiest way for me. I have done 2 cars so far, mine and another member's and it's pretty straight forward.
GL!
JB3 2.0 map 7
j.blackwell's Avatar
j.blackwell j.blackwell is offline
Car: '08 TiAg E90 335i
Tuner: Several
Thumbs up 02-06-2010, 09:55 PM
Two thumbs WAY up. Great job!
Mattssi Mattssi is offline
Car: 2000 Ford Escort
Tuner: 2010 135i Convertible
Send a message via AIM to Mattssi
Default 02-06-2010, 10:33 PM
Awesome, thanks! I just installed 2.0 tonight and I didn't see a simple way to get it out of the ECU compartment...
Will try this tomorrow!
Matt
1st HPFP (881) down @ 1500 miles
2nd HPHF down @ 3000 miles
Fuel Pressure sensor down @ 8000 miles
Tail lamp replaced @ 8500 miles
Lemoned @ 9200 miles
On to the next I guess!
mase mase is offline
Pwner
Car: 07 335i
Tuner: BMS JB3 2.0
Default 02-06-2010, 10:51 PM
very straightforward. thanks for the diy!
shoes's Avatar
shoes shoes is offline
Car: 07 BSM E92 335i
Tuner: BMS
Default 02-06-2010, 10:59 PM
Wow awesome write-up!
I think I should redo mine like this, but it seems like a PITA.
I smashed the rubber grommet down as far as I could then just routed the wire on top of it and out. The ECU box closed up fine. I then just route the wire out from under the hood and into the passenger window. Ghetto, but it works.
TrevorSD's Avatar
TrevorSD TrevorSD is offline
Car: 2009 135i Coupe AT
Tuner: Hmm, I wonder?
Default 02-07-2010, 01:25 AM
Very useful! Thanks for taking the time.
JB3 2.0 Beta 18 ohm| BMS DCI | BT Tool | BMS Tuning Guage | BMS o2 Fix | BMS Stage 3 Chip Burner
AR Design CL DPs |Helix FMIC | KDW2s | H&R Sport Springs | 3M 35% Tint
Coolingmist CMGS Progressive/Fail Safe Meth Kit w/Flow Sensor
ezatnova ezatnova is offline
Car: 335i Coupe
Default 02-07-2010, 07:30 AM
Where do you keep the slack wire that is outside the box? Do you twist tie it and tuck it somewhere in the engine bay? Is the heat situation ok?
enrita's Avatar
enrita enrita is offline
Default 02-07-2010, 07:32 AM
Thanks for this! very usefull!
07 335i AT - TD St.2 Turbos - COBB (Custom Cobb mapping by http://www.protuningfreaks.com/) - JB4G5 - Ported Head - Okada Coils - NGK 5992 Plugs - Injen Intake - Helix IC - Snow Stg. 3 - Stett CP - AR DPs - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
thesalg thesalg is offline
Tuner: BMS
Default 02-07-2010, 09:40 AM
Where are you located? lol
boom boom is offline
Tuner: undecided
Default 02-07-2010, 10:23 AM
How long does this take? Thinking about having to remove the USB cable for dealer visits.
shoes's Avatar
Tuner: BMS
Default 02-07-2010, 11:55 AM
Yea that was one reason I didn't want to go through the firewall. I do not know if heat will eventually cause problems, but the way I have it it's not in direct contact with any heat source.
Anyway, I did it like this....
This is how I routed the wire out of the ECU box. It goes out smashed between the rubber grommet and the ECU box lid, then under the rubber flap up towards the windshield, then out.
(If you push down on the rubber grommet you can create some wiggle room for the cable to rest in, it's not entirely 'smashed'.)
Then I have it just kickin-it in this little niche.
Then when you want to hook up it for datalogging, run the wire up like this so you can still close the hood:
Then from there I just run it in through the passenger side window and to my laptop.
I also put a USB cover over the USB part of the cable and taped it in place to protect it from the elements.
Again, I doubt it, but I not know if heat will eventually cause issues with this setup so do this at your own risk.
EDIT: After having a little more time with the cable in this spot, I would say heat is not an issue. After driving around, to the touch, the cable is no warmer than ambient temperatures.
RevC RevC is offline
Tuner: JB3
Default 02-07-2010, 04:10 PM
nice write up Scott!
if anyone local wants some help with this, I'm sure he'll give you a hand, he helped me button mine up!!
Default 02-07-2010, 05:30 PM
If you're serious, Union, NJ. I have the same SN on e90post.
:D
About 30 mins. maybe less?
JB3 2.0 map 7
LostMarine's Avatar
LostMarine LostMarine is offline
Stalker
Car: E92 DCT ///M
Tuner: BMutha****inS
Default 02-07-2010, 07:42 PM
DAMN!! That ECU box is CLEAN!! I need to upgrade to the PnP!!
E92 DCT M3
SuperCharged
Default 02-07-2010, 08:37 PM
Yes, you should definitely upgrade to the PnP. I helped RevC install his Pin out JB3 2.0 and he's loving it. He's looking into getting a PnP upgrade, too. lol!
:D
JB3 2.0 map 7
Blaizon Blaizon is offline
Car: 2008 E92
Tuner: BMS
Default 02-27-2010, 04:57 PM
Damn, I just installed my JB3, i wish I looked at this before I did the install. I guess I'll do it another day, that large slider ended up kicking my a$$
2008 Sparking Graphite 335i 6MT Coupe - JB4
2007 Montego Blue 335i 6AT Sedan
2002 Oriental Blue 330i 5MT
hondakow0507's Avatar
hondakow0507 hondakow0507 is offline
Luv'n the ride
Tuner: Burger MS/ Dinan
Default 02-27-2010, 05:29 PM
Great info, I'm glad I'm doing all the research up front. Thanks to all of you on this site, can't wait to get the JB3 done. How does this affect the longevity of the engine? If this is already a thread, please just direct me to the link.
Default 02-27-2010, 09:03 PM
If you need help installing your JB3, let me know. I live in Union, NJ.
JB3 2.0 map 7
Forced Air's Avatar
Forced Air Forced Air is offline
Got Boost?
Car: 2010 135i
Tuner: Burger Drink! its.... ....FAST!
Default 03-02-2010, 06:21 PM
I was able to do it without unpluging any of the harness....just pull al lthose grommets up...unclip the whole bracket at the rear of the compartment behind the ecu and lift everything up and forward....easy to get to that hole.
- - My Car Domain - -
2010 BMW 135i AT, AW, ///M Sport
JB4|BMS DCI|Macht Schnell 3" cattless DPs|Golf Tee|33% Tint|///M Pedals
On JB3 & DCI, 91 oct, ~2500 DA
12.85@107.63, 12.86@110.97, 12.96@111.06
Darkcyd335xi Darkcyd335xi is offline
Car: e92 n54 xi
Tuner: BMS JB3 :o)
Default 03-02-2010, 07:22 PM
Damn all you guys did it the hard way....I just took out the DME and fed the usb through. Same place my mapswitch wires are routed for my vent gauge.
Default 03-08-2010, 08:45 PM
If I knew I could do it that way, I would have. lol! Great to know for the next time. lol!
Originally Posted by spydeputy
about how long did it take you to do f/ start to finish ? GREAT DIY, thanks
If you follow the 2 member's instruction above, it should take no more than an hour tops, for everything. Maybe even 30 mins. I think it took me a little less than an hour.
JB3 2.0 map 7
Car: e92 n54 xi
Tuner: BMS JB3 :o)
Default 03-09-2010, 05:30 AM
When I saw the DIY for how the Proceed guys' ran theirs, I knew I could get to the hole in the ECU box by just pulling out the DME. You obviously wont see the quarter size hole like you do when everything is removed, but you CAN see it so you know where to feed the usb. I'm just a real big lazy a$$ sometimes so I wanted to do it with the least amount of work involved.
If you're installing your JB3, takes an extra 5-10 minutes to route through and into the glove box.
JPSlick's Avatar
JPSlick JPSlick is offline
Holla
Car: 2009 335i 6MT
Tuner: Hondata (myself)
Default 03-09-2010, 10:23 AM
Since I'am horrible at removing things without breaking, especially Nazi ECU clips....
I just routed mine through the door when I needed to datalog, otherwise I have the USB routed through the passenger side ECU grommet, and sitting by the ECU box.
I still need to decide where to keep it long term.
For those indivuduals who offered other ways, could you please post pics for refrence, it would really help. (specifically Forced Air).
JPSlick's Avatar
Holla
Car: 2009 335i 6MT
Default 03-09-2010, 10:28 AM
Where you have that wire chilling is where water drains... So just keep that in mind. I would be careful. (aka move it somewhere else LOL)
shoes's Avatar
Tuner: BMS
Default 03-09-2010, 12:54 PM
Yes I've noticed.
It's been through numerous car washes and rain driving - no problems.
The USB cap I have on it works perfect, but it wouldn't recommend this spot without one.
