N54tech.com | BMW N54 N55 135 335 535 Turbo Performance Forum
Car: 135i, 335i, X5D
Tuner: BMS
Default JB4 15 ohm modification - 12-10-2009, 08:18 PM
*** NOTE THIS IS NOT RELEVANT TO THE JB4 G5 BOARD ***
As many know the JB4 G4 board has 18ohm load resistors built in which limit the amount of duty cycle the JB4 can add. The normal 18 ohm resistors limits performance to around 17psi/410rw depending on conditions. This is enough power to run high 11s in a properly setup car. For those wanting more duty cycle/boost you can replace them with 15 ohm resistors to allow another psi or so. Just keep in mind lowering the duty cycle safety increases your risk for motor or turbo failure. You must monitor ignition timing and ensure you have sufficient octane for your boost levels. If you are relying on meth for octane then you must be using a properly configured map 3.
As a general rule, if your FFMAX (wastegate adaption value) is sticking around 130, then you'll benefit by switching over to 15 ohms.
Tools Required:
2 15ohm 5watt ceramic resistors
1 580-620 ohm 1/8 watt resistor. Any resistance within that range will work.
Soldering Iron and Solder
Solder Sucker
Small Wire Cutters
Steps:
1) Cut off 18ohm and 820ohm resistors
2) Use solder sucker to clean out the holes
3) Insert new resistors
4) Solder them
5) Cut off extra leads
6) Verify solder is thorough and if needed clean with rubbing alcohol
Photos below are from a JB3. See JB4 reference photo for correct resistor locations.
BSM 335I's Avatar
BSM 335I BSM 335I is offline
Administrator
Car: E82 135i
Tuner: BMS
Send a message via AIM to BSM 335I
Default 12-10-2009, 09:10 PM
Good to know. Thanks T
5soko's Avatar
5soko 5soko is offline
Car: ML63_335i
Tuner: Terry
Default 12-10-2009, 09:12 PM
Nice write up!!!
Current: ///M5 || ML63 AMG
Retired: 2007 E92 335i || 2010 335i E90 LCI M-sport
Terrance28's Avatar
Terrance28 Terrance28 is offline
Car: BMW 335i
Tuner: JB3
Send a message via Yahoo to Terrance28
Default 12-11-2009, 02:05 AM
Hey Terry maybe you should post some of my diy pics on how NOT to do this haha.
E92 335i Crimson Red|JB3 2.0|Stett Intercooler W/N2o Bung|AFE DCI|Stett Charge pipe W/Meth Bungs|Synapse BOV|Devil's Own Stage1 Kit|Dynotune N2o Stage1 Kit W/Progressive controller & NX noid|ATI Gauge Pod|VEI Boost,A/F Gauge|Cyba Scoops|RR OCC|19" M6 Reps|Aero Lip|Color Matched Grills|Eibach Pro kit|Momo Knob|M3 Spoiler|Carbon8 PD Hood|Vynil Roof|Shadowline Trim|ACS Roof Spoiler|Carbon Interior|MFD M3 skirts|Raceland DP|BMS V3 DP Fix|Magnaflow Race exhaust|
Tuner: BMS
Default 12-11-2009, 09:21 AM
LOL there might be small children reading.
TakeOne's Avatar
TakeOne TakeOne is offline
Too good for 1st gear ;)
Car: 1 Series
Default 12-11-2009, 12:05 PM
cool DIY Terry. Will 2.0 be self-adpating to whatever board one may have? Or will there be some checkbox to select?
I'm just trying to squeeze some 2.0 info out of you if you haven't noticed
Tuner: BMS
Default 12-11-2009, 12:08 PM
It will be self adapting to a degree but may require a few fields to be changed.
TakeOne's Avatar
Car: 1 Series
Default 12-11-2009, 12:11 PM
good stuff!
Rysandro Rysandro is offline
Car: 2009 335i Sedan
Tuner: Burger
Default 12-13-2009, 12:29 AM
I have JB3 1.4, but don't know what board.
Does this mean I have a 24ohm board?
Terrance28's Avatar
Car: BMW 335i
Tuner: JB3
Default 12-13-2009, 01:54 AM
Yes unless you bought it used, just open the jb3 and check.
Maxx2 Maxx2 is offline
Car: 09' 335i
Tuner: BMS
Default 01-28-2010, 03:50 PM
Terry,
Do you have the DigiKey part numbers for the resistors handy? Their website isn't the easiest to navigate. Looking to place an order asap.
Thanks.
2008_335i_coupe's Avatar
2008_335i_coupe 2008_335i_coupe is offline
Car: 2008 BMW 335i coupe
Tuner: Burger Motorsports
Default 02-07-2010, 08:13 PM
I agree on the part number question.
2008 Alpine White 335i E92, 6AT, Saddle Brown Leather, NAV, CF roundels, M3 steering wheel with M3 paddle shifters, Aero lip, painted kidneys (white / black), painted lower grilles (black), debadged, M3 spoiler, M3 side skirts, FK sportline X plus coilovers, 19" CSL wheels.
, JB4 PnP 15 ohm modded, BMS DCI, AA Intercooler, Coolingmist methanol kit, Forge Diverter Valves, BMS 3" Downpipes
yandyr's Avatar
yandyr yandyr is offline
Car: 135i Coupe
Tuner: BMS
Send a message via MSN to yandyr
Default 02-07-2010, 08:40 PM
I just picked them up at a local eletronics / TV Repair shop.. there's plenty around everywhere...
|| 2009 e92 M3 || Melbourne Red || DCT || CF Roof || My Youtube Channel ||
Tuner: BMS
Default 02-07-2010, 08:56 PM
Use the link in the first post.
JPSlick's Avatar
JPSlick JPSlick is offline
Holla
Car: 2009 335i 6MT
Tuner: Hondata (myself)
Default 02-08-2010, 07:50 AM
Terry I forget, does the 18 Ohm benefit the maps 1-7 too or just 8+.
Possibly define "tip top shape".
Tuner: BMS
Default 02-08-2010, 08:46 AM
No, its not suggested for lower maps.
Default 02-08-2010, 09:42 AM
so can I add the resistors to a car with full mods (with meth) and run daily on map 7 or will I have to bump up to map 8?
yandyr's Avatar
Car: 135i Coupe
Tuner: BMS
Default 02-08-2010, 09:44 AM
You'll be fine on Map7, I have an 18ohm board and run Map7 daily.
JPSlick's Avatar
Holla
Car: 2009 335i 6MT
Default 02-08-2010, 12:11 PM
Uh oh lol Ive yet to run it, but I was planning on running 7 with 93 + meth. Using map 8 for the days when I need to take someone out. I was under the impression the only thing that changes was basically there wasnt as much boost taper on the top end.
Just like the poster above I know someone else that has ran the 18ohm on lower maps, and there car didnt "appear" to have a problem. Just curious if you can let us know why its not suggested with some more detail?
Tuner: BMS
Default 02-08-2010, 12:42 PM
You're taking away safety for no upside. Also the targeting tuning is a lot more sensitive and sloppy with the larger load resistors.
JPSlick's Avatar
Holla
Car: 2009 335i 6MT
Default 02-08-2010, 12:44 PM
Are you then suggesting I run map 8 with meth daily? or converting back to 24 Ohm?
I feel like most people daily map 7 with the 18ohm all the time? Ive yet to hear this speculation and information up until today.
I understand the concern for the turbo at WOT, I just didnt know there was that much of a difference in the daily, low to no boost areas.
Tuner: BMS
Default 02-08-2010, 10:42 PM
Do a few JB3 logs on what you have and we can advise you based on that.
Car: 09' 335i
Tuner: BMS
Default 02-09-2010, 10:11 PM
Terry,
I was reading hotrod182's thread "91 Octane + Meth=118MPH" and you wrote the following:
If you are on the modified board you'll make a little more peak boost on map 7, and won't run in to 30FF codes as easily on the higher maps. But at some point we just need to get an intake/IC/downpipes on your car.
Is this still valid with the new 2.0? If so, it sounds like what JPSlick is looking for. I was planning on running the same setup as well.
Wasn't hotrod182 using the 18ohm + Meth on map7 successfully with just DCI?
Tuner: BMS
Default 02-09-2010, 10:42 PM
I think I really spelled it all out in the first post. If the risks are worth it to you for almost no benefit on map 7, go for it!
Tuner: BMS
Default 03-11-2010, 03:12 PM
As we're getting more and more 18 ohm data updated the first post and removed some posts related to changes in the suggestions for use.
