Default BMS Ford F150 Raptor & EcoBoost Development - 01-29-2018, 02:32 PM
Friend of the shop Greg came by today so we could take a peek at his new 2018 Ford F150 Raptor 3.5L twin turbo. Does around 450hp from the factory.
To our surprise, it uses a similar engine management to the BMW turbo models, and I was able to work up Stage1 tuning relatively quickly. Stock boost is around 15psi peak, and for now we've raised that to 18psi peak, to evaluate. The extra power really wakes this heavy truck up!
We've now got Stage1 & JB4 ready to go.
http://burgertuning.com/ford_f150_ra...nce_tuner.html
Stage1 Map Guide:
Map0: Disable Stage1
Map1: 3psi peak over stock
Map3: User adjustable map, boost over stock equal to "boost safety" setting on user adjustment page. For example 4.0 is 4psi over stock
JB4 BETA Map Guide:
Map0: Fully disable JB4
Map1: 4psi peak over stock
Map2: 5psi peak over stock
Map4: Stock map with JB4 CANbus active for logging
Map5: 6psi peak over stock
Map6: User adjustable by RPM map on user adjustment page, values are peak boost over stock by RPM under heavy throttle.
maxboost_R maxboost_R is offline
Car: 2011 E92 335xi
Default 01-29-2018, 07:51 PM
Hey Terry, any plans for the normal 3.5 ecoboost?
2011 AW E92 335i xDrive M Sport Fully Loaded - BMS N55 G5 ISO, Intake, FSB, BMS/CPE Charge Pipe and Trunk Mount Meth Kit | AR Design 4" Catl3ss ******** | BMW Performance Exhaust, Kidney Grills, Rear Diffuser, Carbon ZCP spoiler and Interior LED Lighting Kit | KW V1's | Dinan 15.8mm rear sway bar, Front Strut Tower Bars | Work VS-XX | 3M 15% Tint all around |
Default 01-29-2018, 08:39 PM
Good question... I wonder if it uses the same electronics?
FoShizzle's Avatar
FoShizzle FoShizzle is offline
Car: '11 335is DCT
Default 01-30-2018, 09:07 AM
This is so awesome Terry! Iíll be ordering a Raptor later this year and you were going to be my first call. Boltons are available, but it seems the tuning market for this engine is almost untouched. Canít wait to see what you can do!
TMR's Avatar
TMR TMR is offline
Default 01-30-2018, 10:36 AM
Donít they run 16-18 stock? If you need a test truck, let me know.
Default 01-30-2018, 10:37 AM
We measured 15psi on Greg's but I'm sure boost is load based, so will go up or down depending on the weather.
allanC allanC is offline
Default 01-30-2018, 03:37 PM
Hey Terry, if you also get into the normal F-150 3.5L ecoboost I think you will probably gain a lot more business. They use the same engine in quite a few different platforms. But I would definitely be on board for JB for my truck. And I would be down to be a tester. I also work at a shop with a DynoJet linx system so if you need #'s I can crank them out for you. My vehicle is a:
2016 Ford F-150
3.5L Ecoboost
allmotor_2000 allmotor_2000 is offline
Car: 2014 F10 M5 CP Frozen Grey
Default 01-30-2018, 03:56 PM
Oh my... tow truck!
Default 01-31-2018, 09:44 AM
2016 Ford F-150
3.5L Ecoboost
Yes I'm 99% sure it will be compatible, so we'll have the same tuner for both 3.5L models. With the only change being on the software side.
Email me if you want to help test it out.
Car: 2011 E92 335xi
Default 01-31-2018, 09:44 PM
Terry, if you need more testers for normal 3.5 ecoboost let me know I would be very interested in helping out, I have a 2015 F150 3.5 ecoboost as well.
Default 01-31-2018, 10:14 PM
We've got a handful of systems either in use or on their way. Assuming all goes to plan we'll have the Stage1 BETA up on our site soon to expand the testing pool. The F150 platform at large has a lot more potential and interest than I expected.
Default 02-01-2018, 08:57 AM
you have been e-mailed sir. Thanks
Hippo Tim's Avatar
Hippo Tim Hippo Tim is offline
Car: 2008 335xi e92
Default 02-01-2018, 04:49 PM
It's gonna get real fun, real fast Big T!
2008 e92 335xi *Sport-Cold Weather-Premium*
Performance*JB4 G5 iso*Hexon RR600*VTT intake and HSCP*BMS DCI*VRSF 7" FMIC*BMS meth kit*BMW Performance Exhaust*VRSF 3" Charge Pipe W/ Tial BOV*Trebila Custom Tune via MHD Flasher*xHP trans flash*Fuel-it Stage 2*RB PCV Valve*NGK Laser Iridium plugs(.022)*Eibach Springs*Kickdown Blocker*BMS Cabin Filters*BMS Oil Cooler Valve*Best 1/4-11.58@122
2017 Ford F150* Super Crew Lariat(3.5EB)*
Performance*JB4 Beta*Best 1/4-13.4@102
Default 02-01-2018, 05:39 PM
A local customer got the 2.7L model EcoBoost also, can't wait to check that out.
Hippo Tim's Avatar
Car: 2008 335xi e92
Default 02-01-2018, 06:12 PM
I've heard they are a dark horse. Also think they are running a CGI cylinder block, so a little different from the rest of the EB line-up.
A418t81's Avatar
A418t81 A418t81 is offline
One tire fire
Car: E92 335, 6MT
Default 02-02-2018, 06:24 AM
Very nice! I’ve already flashed mine, but a large market for sure. Looking forward to watching the development.
Ď18 Magnetic Gray Raptor S-crew
'17 991.2 Guards red Turbo S
'07 997.1 6MT: FBO, stock turbos, E85: 5.9 60-130 - 997 platform record, now 656 whp / 700 wtq
A418t81's Avatar
One tire fire
Car: E92 335, 6MT
Default 02-02-2018, 11:54 AM
I also meant to say, 15 psi peak sounds like he may be on the low octane maps. Is he running 91? It may be that the Cali 91 isn't sufficient for the maximum performance maps the factory ECU has. Mine on 93 is 14-15 psi rising to 17, which given normal temps is average with sufficient octane. A max of 15 psi suggests it's running on lower performance maps. I'd have him blend in 5 gallons or so of E85 and see what happens. +3 psi should get you right up to 20 psi high up in the rev range. These ECUs also have dynamic advance as well as retard ignition correction...on E30 and in the lower gears, I've seen it add 2-3 deg of timing.
Default 02-02-2018, 01:32 PM
Yes was running 91 octane. We should start getting a wider range of data in soon on them. I've heard it has built in flex fuel also which would be great.
A418t81's Avatar
One tire fire
Car: E92 335, 6MT
Default 02-04-2018, 02:42 PM
Hmm, I haven't seen the ethanol sensor anywhere. I wish the flash folks would figure out how to balance fuel delivery across the DI and PI during WOT so that higher concentrations of E could be used without crashing the high pressure pump. I've limped mine a few times at low rpm partial throttle, where it'll zip up to 20 psi at around 2k rpm and bottom the rail pressure out to 250 psi, haha. If I don't add any E85 it really doesn't drop too badly, but even E30 I have to semi-keep an eye on part throttle low rpm boost. I've told them they need to limit boost pressure and ride the edge of pump performance up to 2500 rpm or so, but they don't seem interested in doing that. Its good up to about 14 psi at super low engine rpm before any noticeable pressure deviation begins. This is about double the boost pressure the factory runs in this range, as opposed to nearly 3x with the MPT tune.
Fmonteiro444's Avatar
Fmonteiro444 Fmonteiro444 is online now
Car: 09 E92 SG
Default 02-06-2018, 03:42 PM
You NEED to support the 17' Explorer 3.5L twin turbo. Like, you NEED to!
14 F30 335xi AT- JB4 w/MHD Flash, E85, AFE Intake, VRSF 6" Race FMIC, VRSF 4" pipe, VRSF CP, Fuel-it Stage 2 LPFP, PDU PI
////Comming soon: SpeedTech Stage 3 w/ BW-8374 and lot's of BOOST!
09 e92 335xi AT - FBO, RB's, Flash only
11.7 @ 125mph
11.6 @ 116mph (misfire)
Syclone Syclone is offline
Car: 2008 E88 135i Convertiblev
Default 02-09-2018, 11:40 AM
I am up for testing on the 3.5L Ecoboost for the Taurus SHO and Ford Flex. I have both a 2011 SHO and a 2014 Flex - they both have the 3.5L ecoboost.
Jeff Stabell
Lake Wylie, SC
2008 BMW 135i E88 Convertible
Blue/Black
Koni STR.T suspension, M3 Front suspension arms
JB4 Map 7, E85 Backend flash, 255 Gph inline/intank fuel pump, Mechtech Intercooler, Raceland ***, NGK Sparkplugs, DCi, Alpina Trans flash
405 RWhp Dynojet Std (before DCI)
12.37 sec @112 mph (before E85 flash,I/C, 255 FP, DCi)
Default 02-09-2018, 11:57 AM
I'm 99% sure it's fully compatible. If you have one contact me.
Car: 09 E92 SG
Default 02-09-2018, 12:03 PM
I do. And I did. Email is fmonteiro444@gmail
11.7 @ 125mph
Default 02-09-2018, 02:19 PM
Since you have a flash tune already and modified tmap sensor not really the demographic we're looking for to test Stage1. But maybe down the road when we have a JB4.
Helltime Helltime is offline
Car: 09 135i 6mt
Default 02-12-2018, 03:08 PM
Terry, I enjoyed your products on my N54 135i, and 2015 GTI, I hope you end up supporting the 2.7EB at some point. That is my current ride and would be thrilled to have a JB set up for it!
2016 Jetta Sport 1.8T 5MT
2017 F150 2.7 Ecoboost
