N54TECH.COM : BMW N54 / N55 Turbo Performance forum
Banned
Car: 135i, 335i, X5D
Tuner: BMS
Default JB3 hardware versions and how to update - 08-20-2009, 11:41 AM
Had a few questions on the various JB3 configurations and figured it was worth a thread. I'll update it as needed!
There are three production versions, and two beta versions. Pictured below are the three production versions. The beta versions were brown in color and I believe we've exchanged all of them for production boards long ago.
The generation 1 board was sold as shown up until around March, 2009.
Around when we were finalizing 1.3 we added an additional component to the board, the blue 10uf capacitor shown. We found around 5% of cars out there needed this capacitor to run the stronger 1.3 lagfix maps. The G1 board with the extra capacitor is the G2 board.
Around July, 2009 we switched over to the G3 board, which features a DB9 connector on the end for gauge/PC communications and some other changes to facilitate methanol integration. In addition we found some of the G1/G2 cases could melt or deform with the new stronger lagfix maps (which produce more heat) so that was revised on the G3 board as well.
So what does this mean for you? Probably nothing. Unless you have an older G1 board and are having problems with the latest lagfix maps. Problems such as random 2ABC SES codes, or random stumbles only with the lagfix maps under light throttle. The 1.4 lagfix maps are even stronger than the 1.3 maps, and future maps will be stronger, so this may become more of an issue for you. Please note the above symptoms are the only symptoms related to the G1 vs. G2 board and any other problem you may have is most likely not at all related to this.
So if you have a G1 board and find yourself not able to run the latest lagfix maps, here are your options:
1) Send it back to us and we'll update it to G2 for free, update the software while its here, and ship it back to you. Even if you didn't buy it from us. Our shipping address is on our website at www.burgertuning.com and put a note in there with your return address.
2) If you can manage sticking two leads in a hole and soldering them, you can source and solder your own 10uf capacitor to the board. This is the one you need.
3) Upgrade to the G3 board with the latest firmware loaded for $65 here: http://www.burgertuning.com/JB3_upgrades.html
The second hardware item out there to discuss is the JB3 hardware safety. The JB3 has two load resistors designed to limit the amount of wastegate duty cycle the system can pull. This is to protect against a software or tuning problem causing uncontrolled boost levels, and is an important part of the two layer hardware based and software based boost safety system. Especially when users are playing with the tuning using our laptop interface.
The drawback to this system is it limits top end boost at a hardware level to around 16psi peak and 12-13psi at redline. And some of you who use heavy amounts of race gas and modifications want to run more boost than the 24ohm resistors will allow. If you're getting 30FF codes on higher maps and have verified you don't have a boost leak and that your PWM is at 100% when the 30FF comes up, refer to the DIY thread for further details and directions:
http://www.n54tech.com/forums/showthread.php?t=5899
i2istudios's Avatar
i2istudios i2istudios is offline
Photog
Car: 335 Coupe 6MT
Tuner: JB3
Default 08-20-2009, 11:54 AM
Terry, does it matter which direction the capacitor is soldered on?
2007 E92 335i / 6MT / Monaco Blue Metallic / Gray Dakota Leather / Comfort Assist / Premium / Sport / Heated Seats / Navi / Active Steering / Active Cruise Control / Park Distance Control / Rear Sunshade / Sirius MODS PicoTray / M3 Steering Wheel / Front OEM Aero Lip / Bimmian Aluminum Pedals / CDV / Ram Air Scoops / Painted Reflectors / HID 5000k / LED Angels / M Perf. Shifter / Euro Light Switch / 8500 x50 Hardwired / Center Armrest Pouch / JB3 1.3 / BT
Banned
Tuner: BMS
Default 08-20-2009, 11:55 AM
No, its not directional.
Anton335's Avatar
Anton335 Anton335 is offline
Car: 07 335i E92
Tuner: GIAC
Default 08-20-2009, 11:58 AM
Nice info T. So the 3rd. gen came only with gauge connector correct. It's says on the board something like Burger Tuning rev 2.2?
Banned
Tuner: BMS
Default 08-20-2009, 12:00 PM
Right, if it has the DB9 its the G3. Technically there was also a beta G3 but its effectively the same as the production G3.
TrevorSD's Avatar
TrevorSD TrevorSD is offline
Car: 2009 135i Coupe AT
Tuner: Hmm, I wonder?
Default 08-20-2009, 12:09 PM
Good info! I saw a Gen2 board the other day when I was switching out a member's chip and was wondering when the db9 was added.
JB3 2.0 Beta 18 ohm| BMS DCI | BT Tool | BMS Tuning Guage | BMS o2 Fix | BMS Stage 3 Chip Burner
AR Design CL DPs |Helix FMIC | KDW2s | H&R Sport Springs | 3M 35% Tint
Coolingmist CMGS Progressive/Fail Safe Meth Kit w/Flow Sensor
Terrance28's Avatar
Terrance28 Terrance28 is offline
Car: BMW 335i
Tuner: JB3
Send a message via Yahoo to Terrance28
Default 08-20-2009, 12:15 PM
I wonder which one do I have, time to go open it up.
E92 335i Crimson Red|JB3 2.0|Stett Intercooler W/N2o Bung|AFE DCI|Stett Charge pipe W/Meth Bungs|Synapse BOV|Devil's Own Stage1 Kit|Dynotune N2o Stage1 Kit W/Progressive controller & NX noid|ATI Gauge Pod|VEI Boost,A/F Gauge|Cyba Scoops|RR OCC|19" M6 Reps|Aero Lip|Color Matched Grills|Eibach Pro kit|Momo Knob|M3 Spoiler|Carbon8 PD Hood|Vynil Roof|Shadowline Trim|ACS Roof Spoiler|Carbon Interior|MFD M3 skirts|Raceland DP|BMS V3 DP Fix|Magnaflow Race exhaust|
5soko's Avatar
5soko 5soko is offline
Car: E60 M5/ 335i
Tuner: BMS
Default 08-20-2009, 12:19 PM
Great info!! Last couple JB3's are of the Gen3 with db9 connector.
And awesome, AWESOMEEEE customer service!!!
Other tuners make you have to throw away your old hardware and buy hardware for 1,000 dollars, as you are letting us upgrade for FREE!!!! WOW!
HOW-TO: (JB3 Interface)Download,Connect,Datalog,Update firmware.
http://www.n54tech.com/forums/showth...402#post121402
JB3 How-to Map switching video.
http://www.youtube.com/watch?v=cIH0ttIq4Kw
TrevorSD's Avatar
Default 08-20-2009, 12:26 PM
Even if you bought it from someone else... crazy support.
5soko's Avatar
Car: E60 M5/ 335i
Tuner: BMS
Default 08-20-2009, 12:29 PM
Here is a better view of the Gen 1 JB3 with only 1 BLUE capacitor, you can see where there is a open slot for the EXTRA capacitor as per the GEN 2.
brianhn1 brianhn1 is offline
God in Training
Default 08-20-2009, 01:38 PM
You mean capacitor.
JB3 1.3: 12.424s. 116.23mph.
JB3 1.3, DCI, DP: 12.276s @ 114.22mph, +1386ft DA, 3620lbs.
JB3 2.0, DCI, RR DPs, AMS FMIC, RR OCC, Nitto NT555R 275/40R17, soon LSD
335ALIV 335ALIV is offline
Car: E90 335i Black/Black
Tuner: BMS
Originally Posted by 5soko
Here is a better view of the Gen 1 JB3 with only 1 BLUE resistor, you can see where there is a open slot for the EXTRA resistor as per the GEN 2.
I think you meant capacitor... regardless, thanks for the close up.
I'm sure I have Gen 1 in this case. I love soldering, maybe I'll do this mod and it could improve the lagfix maps!
5soko's Avatar
Car: E60 M5/ 335i
Tuner: BMS
Default 08-20-2009, 02:08 PM
Yup i did..fixed.. . NP.
JB335I JB335I is offline
Default 08-20-2009, 09:21 PM
terry, would a cap fix a gen 1 board that has a stutter at 3000 rpm only on the 1.4 lagfix maps?
i'm not throwing any codes, and the hpfp was replaced about a month ago.
also, do you have any extra caps? the shipping fee is 10X more than the cost of a single cap from mouser. i'm guessing a postage stamp would be enough to handle the shipping
Banned
Tuner: BMS
Default 08-20-2009, 09:39 PM
Only lagfix maps and only at light throttle? It might. Drop me an email with your addr and I can send a cap out.
5soko's Avatar
Car: E60 M5/ 335i
Tuner: BMS
Default 08-22-2009, 08:47 PM
Thanks alot Terry for the fast shipping! Really appreciate it! Great customer service as always!
Here are some pics from my cell
And while i had my cousin car there, JB3 for E55 AMG?
Anton335's Avatar
Car: 07 335i E92
Tuner: GIAC
Default 08-22-2009, 09:32 PM
It's time for that BMS gauge to fill that other side of JB3!
carcars 335i's Avatar
carcars 335i carcars 335i is offline
Car: 335i e92 jb3
Tuner: N54 currently the fastest in Spain
Default 09-01-2009, 11:57 AM
not understand how my JB3 is a g1, if purchased in May as possible 2009.no understand ?????:cryI have to do, send the JB3 to the United States???
Banned
Tuner: BMS
Default 09-01-2009, 11:58 AM
Just order the cap and solder it in, or we can send you one to solder in.
Car: 335i e92 jb3
Default 09-01-2009, 12:21 PM
are what you tell me, what is best for you if you pay $, I pay usted.creo you tell me I have to do this to make this more trankil
Banned
Tuner: BMS
Default 09-01-2009, 12:46 PM
Email me address and we'll mail you a cap to add. It's easy to do.
tomtom tomtom is offline
Car: 335I
Default 09-01-2009, 12:53 PM
can someone post a pic on how to solder the cap to the board.
Banned
Tuner: BMS
It's in the first post.
Car: 335i e92 jb3
Default 09-01-2009, 12:58 PM
va para ya
AW135i AW135i is offline
Default 09-02-2009, 06:28 PM
Hey Terry,
I just found out that I have a G1 board. That may explain why my car stuttered 3 separate times during high load light throttle situations. I was running rev 6 map 7. The last couple of days I have been running map 8, car is smooth with no issues. Any chance you can mail a capacitor to me?
Thanks,
AW135i
vB code is On
Copyright © 2007 - 2010, N54Tech.com | BMW N54 / N55 Engine Forum
